Results 1 to 13 of 35
    Jul 2011
    Heat strip sequencer
    I think I have a bad sequencer, but I'm not 100% sure how they work.
    It is receiving 24 volts and has 240v coming in one side, but not on the other side ( connected to strips ).
    Can anyone explain to me how they are supposed to work?
    Jan 2010
    Quote Originally Posted by Honesttech View Post
    More like 120 on one side of strip and 120 going thru sequencer then other side of strip.
    Mar 2010
    Kent, WA.
    somebody correct me if im wrong but this is how they should work. the 24v signal heats up a bi-metal strip inside the sequencer. the heating of the strip makes it into a switch basically. sequencers have time ratings to switch on. basically they are used to trigger the heat strips in different intervals. this way you have lets say a 30kw heat strip and your sequencers would bring on 10kw and then some time later another 10kw and again some time and your last 10kw. this is the basic design and it keeps from 30kw in this example from coming on at one time, decreasing your demand charge from the utilities and dimming the lights.
    Virginia
    See attachment.
    Jul 2011
    Thank you. That's exactly what I was wondering, is what closes that switch?
    And it is 240v going into the sequencer, but not coming out.
    Mar 2012
    Connecticut
    Thank you very much for the file.
    Jul 2011
    Well, looks like I screwed up all over the place on this one. My lack of knowledge on sequencers was quite obvious here. I wasn't even right about the high voltage. It turned out that the 24 volt common was connected to the wrong 24 v side of the contactor coil. So, basically the sequencer had no common. Thats it.
    Lesson learned...... the embarrassing way.
    Feb 2012
    Alabama
    Lessons learned the embarrassing way are usually not forgotten. One tip on the high voltage, you may already know and if so just disregard. If you measure voltage across a switch it is most likely open. Can turn power off and remove the high voltage wires, then turn power back on and use ohm meter to be sure.
    Quote Originally Posted by Tech it out View Post
    "turn power back on and use ohm meter"?
    Feb 2012
    VA
    Quote Originally Posted by rundawg View Post
    See attachment.
    you can allways count on rundawg
    Feb 2012
    VA
    cool
    Feb 2012
    South Georgia
    See attachment.
    actually there is a ceramic post that sits on top of the bi-metal disc, when the disc is heated it "clicks" changing shape from converse to convex pushing the ceramic post up and closing the circuit. on double stack seq. there are two discs , one for each switch, the difference is the two bi-metal discs have different temps and convex angles. take a bad one apart and examine it, you will see what im talking about. seq. is a bad design due to its thermal reactance and intermittent operation
    Feb 2012
    Alabama
    Nope now that wouldn't hardly work would it? But if you removed the high voltage wires with the power off, then turned the power back on like I wrote, it would work like a charm with an ohm meter now wouldn't it?
