+ Reply to Thread
Results 1 to 17 of 17
Thread: Strange position
    Simple little HP changeout
    The decedent...
    The beautiful & quiet replacement. NOTE: the HO wanted it at this crazy angle!!!
    Burleson, Texas
    The disconnect..........
    Yea, that's where the wire comes out of the wall. Could have easily been raised.
    Jul 2005
    Orange County, NY
    Why is it raised?
    Core
    Rochester, MN
    Wow. that unit is large.. How many ton?
    Able to get back there and service it?
    Originally posted by core
    Why is it raised?
    Core
    It's a Heat Pump.
    Jul 2001
    Anderson,SC
    What is the code min above ground for disconnect? Is there a water issue or is snow that high in winter? Why the unit raised, don't do that in SC. Where is the required 120V outlet? You do upgrade to code on installs don't you.
    STUD
    Nice dryer vent!
    South Carolina
    hvac stud were in sc are you cola town here
    Apr 2003
    Smokies
    Why is it raised?
    Core
    Legs to keep it out of the snow in the winter.
    Memphis
    replace the coil?
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    Jul 2001
    Anderson,SC
    papa_jo
    I'm in Anderson, SC. Check my profile. Where are u?
    STUD
    South Carolina
    columbia sc
    manitowoc wisconsin
    Why is it raised?
    Core
    It is for drainage.When a heatpump goes into defrost it will melt off any frozen moisture on the coil.It runs in the winter below freezing temps if not raised it could dam ice up & block the coils.
    Take your time & do it right!
  14. #14
    newton,mass.
    Baldloonie: How did you move the unit that required those blocks on the ground? These new larger units are going to screw up things for guys that work alone, or have limited space in their trucks. Did one last week that I had to get behind the building and the ground was very uneven, man did that suck. Well anyway you did well, keep up the good work.
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
  15. #15
    Apr 2004
    Bald, are those goofy pads in front of the unit permanent?
  16. #16
    Yea, he had those stones in front of his last unit so I would expect them to stay!
  17. #17
    South Amboy, NJ
    man, the original unit looked like they barely left enough room to open the disconnect
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
