Results 1 to 13 of 17
    north suburbs of Chicago
    Got a home inspection story?
    Some real clowns out there.
    A) Guy calls in spring, no cooling. Had home inspected, all was good including a/c. I walk out to unit. No condenser motor, blade, mount. My guess is it went bad at the end of previous summer and the service guy went to match it up and it ended there with the previous owners.
    B) Lady buys home that I worked with at her previous home. Again all is well per home inspector pro. I get out a month later for routine service. Bed and bath addition above garage heated by furnace in garage. All return air is being taken FROM GARAGE! To this day she is using electric space heaters.
    This does not even count all the others that I could have told them in two minutes the addition on the slab will never heat or the second floor will never cool.
    Jun 2006
    Richmond, VA
    1. Inspector starts an infinity heatpump in heating in 90 degree weather and writes on his report "HP not responding to controls"....duh, it's protecting itself from your dumba**
    2. Also writes: "Master bedroom shower has no pressure"....Duh, the shower wand button is shut off......
    I wish I had a $1.00 for every response I deleted.....
    1. "your ductwork is too small"
    2. "your system is too big"
    3. "You Need a New contractor" Your's might be okay, but if it's not ME working on your system-your contractor must be a loser-I can see it from here.
    Feb 2012
    san pedro ca.
    You can buy a home inspection license any day of the week. Doesnt mean they know squat.
    Quote Originally Posted by beshvac View Post
    They are prizes. I had another. The first thing you see when you walk downstairs is the furnace and water heater. You can not miss it! All is fine with inspector. The water heater was 17 feet away from the chimney with a rotting out flue cause by a pitch of about 1 inch in 17 feet.
    I had to replace tank, relocate it and run gas and water lines.
    Jan 2012
    Broomall, PA
    Hey, at least your inspectors....
    are taking a crack at it--a poor crack at it....at best. In our area they just write, "appliance needs to be checked by qualified license technician". Which works out just fine for me.
    Jul 2009
    Ontario, Canada
    Quote Originally Posted by STEVEusaPA View Post
    that's the way I prefer to have it. I've had many calls like this where the home inspector recommended a qualified service technician--and in some cases, I'm really glad they did!
    Dec 2011
    The People's Republic Of Maryland
    We've come across a few oil furnaces in pretty piss-poor condition, sometimes with cracked heat exchangers. Tough to tell someone who's just moved in that they need a new furnace! "But the home inspector said it was fine, I KNEW we shouldn't have used the guy the realtor recommended!"
    Quote Originally Posted by GorillaTight View Post
    Yep! I had an oldie once that was passed. I don't recall if it was an gas in-shot burner conversion now or what.
    I just remember that the furnace jacket down by the burner was glowing red when the thing fired up!
    Rochester, NY, USA
    I put a 120K btu 80% furnace in for a o-l-d customer, I used HVAC-Calc, SHOWED the results to the HO's, who btw is a controls guy.
    About a year later I go and do a Inspection because he decided to sell the home and he needed a certification/inspection report. I give him my blessing (report) along WITH THE MANUAL J
    Along comes a buyers "home inspector" and he tells everyone within ear shot that the furnace is way over sized and "someone should derate the furnace buy removing two burners and plugging the burner jets"
    The HO'r is calling me in a panic and calling me all kinds of names. I say "gezzz, calm down, how did this guy figure the furnace was over sized"
    I swear to God this is what he said,
    HO'r "he looked at it"
    Me "{total silence}
    HO'r Jmac, you there"
    Me " uuum Ya~~~*He looked at it*~~~you want to think about that for a second, and then repeat it, do you still have my COMPUTERIZED Manual J"
    HO'r seriously, I am so sorry
    ME, "put the genius on the phone"
    HO'r "That might not be a good idea"
    ME "sure it will, it will be a freaking blast, trust me make sure the potential buyer is standing close by to"
    HO'r sorry to bother you Jmac, buy...click
    unfreakingbelievable
    Skilled Workers are hard to find
    Thats why idiots are promoted to management
    Classic!
    Quote Originally Posted by jmac00 View Post
    Me "{total silence}
    Mar 2001
    Ilwaco, Washington
    Realtor calls and asks m to check out a heat pump system on a house that is about to close. House inspector says the heat pump outdoor unit isn't operating. Go check it out, ambient about 40 degrees. Thermostat alling for heat. Inspector is right. A/C unit isn't running. Electric furnace, and A/C unit. Not a Pump! Potential buyer not happy!
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    S.E. Pa
    Thumbs down other side of the coin
    I was called to look at the exterior of a masonry chimney serving the heater. I begin finding serious deterioration and damage up top. Ask to see the furnace> basment. Carrier oil fired furnace:
    chimney connector runs downhill
    chimney connector didn't have a single screw in the joints
    chimney breaching 100% blocked from a collapse
    barometric damper too far from appliance with counterweight set for vertical when on a horizontal run and totally blackened from backdrafting
    no duct sealing anywhere
    humidifier hanging open
    non-std size filter rack without cover for filter slot
    no filter anywhere for oil line
    no Firomatic valve
    oil line badly kinked
    condensate pump has live 120vac wires twisted on prongs of plug then taped--no outlet or hardwired junction box
    Unit being fed by a Federal Pacific panel
    Unit has been serviced 7 years by the leading oil service provider in the area who's owner sits on the local council.
    What's this got to do with home inspectors? Nothing. I just wanted to show how easy it is to bash someone else. So, how productive do you think this thread is? Make you feel like a big man? Boy, you really showed what clowns they are, right?
    Have you ever met with a HI and discussed some basic misconceptions? Ridden along on an inspection or two? Spoken at their monthly chapter meeting? Passed out cards and referred business to each other?
    You guys continue to kill the goose that could be laying golden eggs for you. I don't hear any praise of thanksgiving when HIs send you work that is legit? I know they do find a LOT of stupid stuff. Stuff done by supposedly professional HVAC contractors. It goes both ways. Visit their blogs and look at some of the crazy cr@p they find. Walk a mile in their shoes.
    Home Inspectors are 'generalists'. That means they know something about all the various aspects of a home. Their standards of practice prevent and protect them from going over their heads. When they do go overboard or screw up, the client does have recourse, which is why they have to carry expensive professional liability "errors and omissions" insurance. Do you?
    Rochester, NY, USA
    Quote Originally Posted by hearthman View Post
    Generalist's? no kidding, Have have soooo much respect for a guy that can LOOK AT A FURNACE and tell it's over size. Genus, pure genus
    I have a lot of respect of a guy that crawls up a ladder, looks in an attic with 60 year old 2" insulation and report, "yep, looks like R-38 to me"
    erros and omissions? have you ever read the last Paragraph of their 'report' it basically says, "we ain't responsible for anything, we looked, we saw, we billed. have a nice day. If something pops up later, ya well sorry about that, tough nuggies"
    YES! EVERY profession has there hacks, Home inspectors seem to have an over abundance of them. I suppose thats because anyone with a clipboard, flash light and a Station wagon can call themselves a "Home Inspector"
    NOW! you want to talk about BUILD/CODE enforcement? You want to talk about Build performance/engineering firms. Im all for those folks. At least they have something more than a clue
    sorry, but I don't like or trust a "home inspector" I'll call an engineering firm, someone that has structural/plumbing/electrical knowledge, I'll pay the extra bucks to have a couple guys with a Phd or Masters in engineering look ay my potential new home.
