Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 62
  1. #40
    Atlanta,GA.
    you can always call the manufacturers customer service line and list a complaint against the company if they are an authorized dealer
  2. #41
    Doubt you'll find many systems that had nitrogen flowing through their line sets in new construction. And they do last a long time.
    Should he have done it? Yes. Is it going to have a problem because he didn't? Only time ill tell.
  3. #42
    Houston,Tx.
    Quote Originally Posted by John Markl View Post
    If the OP KNEW it was supposed to be purged during the install, and he WATCHED the installer braze without purging, he should have stopped the job ON THE SPOT, and called the owner to resolve it then.
    Good point! I guess if he bought a new Corvette and it was supposed to be Blue, when they brought a Red one out, he would just get in and drive off?
  4. #43
    Houston,Tx.
    So it would be your contention, that even though the manufacturer requires it in there installation instructions, if it is not written in the contract that it has no merit?
    Your required to drive the speed limit and come to a complete stop at all stop signs or red lights, you ever broke either law? if so your as bad as the guy that did not flow with nitrogen, because the law states in there instructions to do so.
  5. #44
    Virginia
    Quote Originally Posted by kitra View Post
    OK, they've been paid-in-full. Here's some more detail - I called the installer at the time on the fact that he was not using a nitrogen purge and he looked stunned. Then he continued to braze and said his nitrogen tank and regulator are back at the shop (5 miles away). He insisted it would be fine. Then he started to evacuate the system and took off for lunch. Came back and finished up. The company insists nitrogen purging in not necessary but I've heard it's more critical with R410A. So they got their money, we got a nice system that hopefully won't fail anytime soon. And yes, it does say to purge with nitrogen in the installation manual.
    So he did not pressure test it either. Lets see here. #1 he added a unneeded drier in the liquid line #2 he did not purge with nitrogen #3 he did not pressure test the system and #4 he did not use a micron guage these are the known items he blew it on makes me wonder
  6. #45
    Nov 2007
    Sherman, TX
    Quote Originally Posted by catmanacman View Post
    Do we know these other things to be fact, or are we making assumptions?
    Technical incompetence is NOT a sales tool....
  7. #46
    you paid him, it's over . . move on ..... now do your part & make sure you maintain the system .. change filters regularly & have your unit inspected at least once a year .. thank you & have a great night
    Sent from my HTC Sensation 4G using Tapatalk
  8. #47
    S.E. Pa
    Cool
    you are obligated to install the product to the mfrs. listed instrucitons. Now, some things in IOM manuals are mandatory and others are considered 'best practices'. Before you hang this guy out to dry, you would need to document where it is written as mandatory he purge with nitro. Sure, most guys have heard it for yrs we should flow N2 but a lot still don't and mfrs. just don't have the budget to test and prove a compressor failed because the tech skipped the N2 and the resulting crud killed the system.
  9. #48
    Virginia
    How would he pressure test the system if he did not have nitrogen or a regulator
  10. #49
    Nov 2007
    Sherman, TX
    By opening the valves on the condensing unit and using a leak detector, eyes, ears, and maybe soap bubbles?
    Nitrogen isn't the only way to leak check a system.
    Now, about that micron gauge....
  11. #50
    That would be an EPA violation.
  12. #51
    S.E. Pa
    Thumbs down please close this thread
    First of all, we're trying a case in abstentia. We weren't there. We don't have pics of the guy working. We can only go by what the homeowner has related to us. The homeowner is withholding payment based upon information gleened online from a blog. How would you feel if someone stiffed you on those terms?
    She may be telling the whole truth or there may be more to it. We don't have the IOM manual, what local codes are, what the mfrs warranties say about it, etc. I really think this thread needs to die out since it does no good to anyone.
  13. #52
    Virginia
    Im ass u me ing
