Results 1 to 10 of 10
    Sep 2011
    Augusta, ME
    Flame rectification circuit
    On a electronic ignition intermittent pilot ignition control is there any known methods of testing the flame sensor besides measuring amperage? Was curious if any techs had different tricks or techniques.
    Feb 2012
    san pedro ca.
    The only way to check the amperage on a flame sensor is to plug it into a wall socket, Don't do that.
    Quote Originally Posted by sgagne199
    Not that I'm aware of.
    Southeastern Pa
    X2.
    Microamps, pulsating DC.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Feb 2012
    Upstate SC
    Some of the newer controllers will do that for you. Other than that I agree with the other posts.
    Sep 2011
    Augusta, ME
    Ok thats kinda what i figured thanks for the input
    New Mexico
    You can find manufactuers that make test devices like Honeywell made for the 890's and Fenwall made. What brand of control is it?
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Southeastern Pa
    Quote Originally Posted by jburchstead View Post
    True. Some will give you a voltage reading that is intended to mimic the microamp reading.
    BUT, the approach being take is the same, regardless of having a circuit do the work for you.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    SouthEastern Virginia
    Hey coilcleaner, that's the stupidest thing I have ever heard
    It might get loud!
    Jan 2002
    As mentioned above there are several types of flame simulators on the market depending on type something like this: http://cgproducts.johnsoncontrols.co...PDF/121835.PDF
    Two wire hook up, three wire f**k up.
