Results 1 to 13 of 19
03-04-2012, 04:21 PM #1
- Jan 2010
- 4,410
REPLACING REFRIGERANT CONTROLS WITHOUT REMOVING CHARGE
I was looking at a Manitowic service manual today and found this " This is a required in-warranty repair procedure " using a pinch-off tool. I have one but never use it. Anyone out there using one ?
03-04-2012, 04:44 PM #2
Manitowoc recommends a pinch-off & re-rounding tool for replacing stuff like the fan cycle or high pressure control. I've used one for years, more often to add service access valves to True units and such.
Here's a past post on that tool:
http://hvac-talk.com/vbb/showpost.ph...32&postcount=5
(The Ritchie P/N is #60665)
03-04-2012, 04:49 PM #3
I have a pinch off tool, but have never used it on a live system. Just scrap copper in my Van and when I re-round it, it never resumes it's original round shape...it definitively re-opens the pinch off, just not round.
You able to make them round again Ice?
03-04-2012, 04:55 PM #4
Mine come out maybe "75% round" which is fine for a pressure control or access valve. The trouble I've seen is the pinch point is weakened and so it may fail due to vibration. I've had good luck with building up the pinch point with a little silphos to stiffen it a bit.
03-05-2012, 02:15 PM #5
- Jan 2010
- 4,410
The first and last time i used my i was trying to remove a condensing unit. On the 1/4" liquid line it would not seal it off. When i cut the line it keep spewing out. I tried to pinch it down more and it ended up cutting it.
Also are you even a little concerned about welding a charged system ?
03-05-2012, 03:22 PM #6
If you have the room I pinch it twice about an inch apart. They never come out round but it can save you a lot of time.
I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
Veto Pro Pak - The best tool bag you'll ever own
03-05-2012, 04:34 PM #7
When you braze on an access valve, it's not on the charged side of your pinch-off point...so it's not a problem.
As for adding some braze to build up the re-rounded portion, I don't see that as a particular problem.
I've never cut one off with the pinch-off/re-rounding tool, but I know I've come close...hence the buildup of brazing material suggestion.
I've done that a couple of times when I can't get the first one to hold for whatever reason. Good tip.
03-05-2012, 09:46 PM #8
- Apr 2007
- Scottsdale,AZ
- 58
I use pinch off tools regularly. Lots of tools out there but not all are good for service. I always look for a aset that doesn't touch in the pinch area. Mine round well and have never had a problem. Imperials.
03-05-2012, 10:49 PM #9
- Jun 2009
- Garland, TX
- 349
I actually saw a Manitowoc CVD unit that some hack had replaced the headmaster by using 3 pinch off tools... lame! It wasn't flowing enough during harvest, maybe because pipe only re-rounded 50% or maybe because he used an off the shelf part with 180# set point... Either way that was pretty interesting to see!
I have used pinch off tools a lot for sealed system access. But I don't like to use them on discharge lines like for a rooftop condensing unit because I've been on at least 3 calls where a discharge line access valve broke at the pinched off section.
Anytime I pinch off for a sealed system, once I recover, I cut out the pinch-off section.
03-06-2012, 01:41 AM #10
I have used one for years , never had a problem with them, but mainly use them for true boxs and manitiwocs as others have mentioned.
3 pinch off tools to change a headmaster? why didnt' I think of that
Love makes the world go around but cash pays the bills
03-06-2012, 12:32 PM #11
- Jan 2010
- 4,410
O.K. after seeing your commits here next opportunity i'll give it another go. One more thing comes to mind. Are we not worried about trapped AIR ?
03-06-2012, 12:34 PM #12
- Jan 2010
- 4,410
03-06-2012, 02:33 PM #13
