Results 1 to 13 of 17
    Jan 2012
    Pakistan
    York Centrifugal Chiller Half phase fault
    We have three York centrifugal chillers with the following spec
    Series YT Codepak
    Unit Model YTH3J3E35COG
    Refrigerant R123
    Capacity 500 Tons
    Compressor Model YDTL.126
    Starter SSS 26L-50A (LCSSS)
    One of them was under maintenance and we replaced its shaft seal. Now when it was taken again in service it has started tripping on 'half phase' fault.
    I've changed the trigger board with a new one and also swapped it with the chiller which is working fine but to no avail.
    Took the resistance readings of each thyristor as well as the J6 to J11 points on the cards. Found one thyristor short and replaced it. Now all the resistances of the thyristors are between 15 and 20 ohms as per the York Manual. Secondly, each of the points on the board has a resistance of around 200 ohm as per the board.
    What could be the issue here?
    The chillers have been service since 1996 and before maintenance it wasn't any half phase fault.
    Dec 2008
    Dixiana, AL
    This is not necessarily a subject for the open forum. Get your post count up and go pro.
    And what are you calling a thyristor?
    Jan 2012
    Pakistan
    Quote Originally Posted by klove View Post
    SCR
    check for broken SCR Gate Wire. There are 2 SCR Gate Wires for each Phase.
    If not broken SCR Gate wire, swap LOGIC Board with one on the working chiller to try.
    Somewhere in the world.
    Half Phase Trip Fault
    DETAILS
    Locate your copy of 160.46-OM3.1 (SB9 & SB11), and then replace it with this literature supplement!
    When troubleshooting a half-phase trip, it is first necessary to determine if the situation is a real event caused by a
    starter malfunction, or a false trip caused by electrical abnormalities. We have been seeing an increasing number
    of false trips lately, so we suggest you rule-out the typical false trip conditions fi rst. The three known causes of
    false trips are:
    1) High Line Voltage, greater than 500VAC on a 460VAC nominal system, for example. More than 10% above
    nominal.
    2) Large Variable Speed Drives on same power distribution, or many smaller drives in combination. Most VSD’s
    create voltage distortion, which distorts our chillers motor’s waveform.
    3) Significant Current Imbalance, greater than 15% from highest leg to the lowest leg. Look at the Control Panel’s
    display just prior to tripping. Note: the highest and lowest values, subtract to get the difference, and divide this
    number by the value of the lowest leg. If the answer is .15 or more, current imbalance is likely the cause. A
    1.5% voltage imbalance will create a 15% or greater current imbalance. The exact amount of current imbalance
    varies with motor load (%FLA), and increases as the motor unloads.
    If tripping is caused by one of these conditions, it would be best to correct the problem at the source, i.e. change
    transformer taps to lower voltage, put fi lters on VSD’s, or balance out single phase loads to bring voltage balance
    to within 1%. If this is not possible, you may have no choice but to eliminate the 1/2 phase circuit. On older
    rev. ‘D’ through rev. ‘F’ boards, you will need to solder a wire jumper as shown on Fig. 1. On (Rev G) and
    newer starter logic boards, there is a jumper wire, JP1, located approximately 1.5 inch below the large
    black heatsink in the upper right corner. Cut this jumper to disable the 1/2 phase circuit.
    If none of the three above conditions exist, you likely have a real problem in the LCSSS, and should troubleshoot
    the starter. The 1/2 phase indicator is intended to signify that one of the six SCR’s is not fi ring. Most common
    problem areas are the trigger board, connections from the 3-wye to the trigger, and connections from the trigger to
    the SCR’s.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Jan 2012
    Pakistan
    Quote Originally Posted by york56 View Post
    DETAILS
    false trips are:
    nominal.
    the SCR’s.
    Thanks for the reply. I dont have a copy of this supplement and cant find it online either, can you email me that?
    Thanks again
    Jan 2012
    Pakistan
    Quote Originally Posted by w~p View Post
    Done the swapping already. Two SCRs were indeed short. One had a shorted gate and the other was anode to cathod short. Now all are OK but still the half phase.
    Swapped the trigger logic board as well without success. We have three of these chillers, same model, spec, supply source but this has been nagging since its shaft seal was done.
    Quote Originally Posted by snsici View Post
    Thanks again
    You won't find it online and you profile is missing alot of information regarding yourself.
    Jan 2012
    Pakistan
    Updated it.
    Updated it.
    Check your mail.
    Jan 2012
    Pakistan
    Check your mail.
    Haven't received anything yet.
    DETAILS
    Please let me have them too.
    Thank you
    Jan 2012
    Melbourne
    York yrvc
    Hi do u also have the service manual 160.81.m1 I'm have trouble with this chiller failing on low differential oil pressure! Any hints
