Results 14 to 24 of 24
03-03-2012, 10:05 AM #14
Bernoulli's Principle only applies if the velocity inside the pipe that has a small hole is so high that it starts drawing air into the hole and not letting any refrigerant out.
Lets just take a low temp running R404a with a -15 evap temp, 20 psig, and a small hole in the suction pipe. The velocity would have to be extremely high to ever reverse the 20 psi gas leaving the pipe and start drawing in air.
For a leak to leak gas out and suck gas in at the same time is completely impossible. You either have to take the pressure inside the pipe down to negative, or get the velocity so high it would create a slight vacuum at the leak(not gonna happen in a refrigeration system, velocity would never get that high). Maybe if you got the pressure down to .5psig you might have enough velocity to suck a little air in, maybe.
Urban Legend.
The more likely cause of getting moisture into a system would be having a leak in the low side and some intermittent restriction causing negative pressures at times, or a pump down system that is pulling down into a vacuum due to pressure switch set wrong.
03-03-2012, 10:32 AM #15We need the Mythbusters!!
Originally Posted by chuckcrj
03-03-2012, 12:15 PM #16
- Nov 2010
- MN
- 104
Check out this video on YouTube of a guy pulling a vacuum on a clear bottle of POE that came out of a new scroll compressor.
03-03-2012, 12:18 PM #17Means nothing.
Originally Posted by PMARS2345
Yes, some moisture came out of the oil.
After he's done, send that stuff out for an analysis and see what the moisture content is.
You'll be in for a surprise.
03-03-2012, 12:51 PM #18
- Nov 2010
- MN
- 104
Quite a few statements on Poe oil here, any references to back then up? I'm nottt doubting what is said would like more info for learning?
03-03-2012, 03:03 PM #19
http://sporlanonline.com/November%20...Cold%20WAR.pdf
There is a start.
There are many, many threads here on this topic. Use the search feature.
03-03-2012, 03:08 PM #20
- Nov 2010
- MN
- 104
03-03-2012, 05:24 PM #21
- Feb 2012
- PA
- 27
POE is definitely a cock sucker.. Had a bad burnout years ago and tried for days to clean it up. The only thing that seemed to work was heating and agitating the areas of the system with oil laying in them(crank case, seperator, suc line trap, and accumulator). After 2 days of runing, the oil tested ok in the field, but im sure a lab analysis would probably show that some moisture content was still there.
03-04-2012, 06:58 AM #22[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
03-04-2012, 05:02 PM #23
- Dec 2011
- bedford ind
- 1,080
maybe he had too much water in the bottle for such a short time it couldn't all be absorbed.
03-04-2012, 06:55 PM #24
- Nov 2010
- MN
- 104
