Results 1 to 13 of 29
    Mar 2011
    Hawaii
    AB to POE oil conversion
    Has anyone changed out a racks oil from AB to POE? If so any problems? Thoughts? I want to this so we can change out the gas and get away from the HP80.
    We the unwilling, working for the unknowing, are doing the impossible for the ungrateful. We have done so much with so little for so long, we are now qualified to do anything with nothing.
    Oct 2011
    Harrisburg, NC
    It would be no different than changing from Mineral to POE. Maybe a few more oil changes.
    I can definitely understand getting away from the HP80. What are you planning on going to?
    I can't fix it if it won't stay broke..
    Mar 2011
    Hawaii
    Were going to retro to 404a.... HP80 is big $$$$$$ these days
    Oct 2011
    Harrisburg, NC
    Have you looked into all the other work you are going to have to do for conversion? Gaskets. Certain types of ball valves. Just about anything that has a rubber gasket has to have the gasket changed.
    Mar 2011
    Hawaii
    Quote Originally Posted by CRussell1975 View Post
    Yes. Ive done a few smaller sattelite systems...just not an entire rack.
    Oct 2011
    Harrisburg, NC
    Its no different, just more of it.
    One thing I have seen overlooked is the older ballmaster ball valves with the acorn nut. They leak.
    Mar 2011
    Hawaii
    [QUOTE=CRussell1975;12623311]Its no different, just more of it.
    One thing I have seen overlooked is the older ballmaster ball valves with the acorn nut. They leak.[/QUOTE
    Most of those valves I HAD leaked before the retrofit!
    Oct 2011
    Harrisburg, NC
    Good Point.
    Vancouver Island, B.C.
    Instead of that POE with all it's inherent problems, have you considered PVE?
    "The quality you deserve is not expensive---it's priceless"
    Oct 2011
    Harrisburg, NC
    Other than scouring a system and possible TXV screen stoppage with the resulting scale, what inherent problems do you speak of my friend?
    What is PVE?
    What is PVE?
    Moisture issues and hydrolysis.
    PolyVinyl Ether oil.
    Las Vegas, Nevada
    Okay, I guess I'm at the back of the class as well. Never heard of PVE.
    The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
    California
    Quote Originally Posted by engineerdave View Post
    any spare seats left?
    I may have heard of it, but never seen it, so never cared about it
Tags for this Thread
