Results 1 to 13 of 29
Thread: AB to POE oil conversion
03-02-2012, 12:55 AM #1
Has anyone changed out a racks oil from AB to POE? If so any problems? Thoughts? I want to this so we can change out the gas and get away from the HP80.
We the unwilling, working for the unknowing, are doing the impossible for the ungrateful. We have done so much with so little for so long, we are now qualified to do anything with nothing.
03-02-2012, 11:06 PM #2
It would be no different than changing from Mineral to POE. Maybe a few more oil changes.
I can definitely understand getting away from the HP80. What are you planning on going to?There's no such thing as normal,Just different kinds of crazy..
03-03-2012, 12:10 AM #3
Were going to retro to 404a.... HP80 is big $$$$$$ these days
03-03-2012, 12:17 AM #4
Have you looked into all the other work you are going to have to do for conversion? Gaskets. Certain types of ball valves. Just about anything that has a rubber gasket has to have the gasket changed.
03-03-2012, 12:29 AM #5
03-03-2012, 12:36 AM #6
Its no different, just more of it.
One thing I have seen overlooked is the older ballmaster ball valves with the acorn nut. They leak.There's no such thing as normal,Just different kinds of crazy..
03-03-2012, 12:41 AM #7
[QUOTE=CRussell1975;12623311]Its no different, just more of it.
One thing I have seen overlooked is the older ballmaster ball valves with the acorn nut. They leak.[/QUOTE
Most of those valves I HAD leaked before the retrofit!We the unwilling, working for the unknowing, are doing the impossible for the ungrateful. We have done so much with so little for so long, we are now qualified to do anything with nothing.
03-03-2012, 12:46 AM #8
Good Point.
03-03-2012, 01:40 AM #9
Instead of that POE with all it's inherent problems, have you considered PVE?
"The quality you deserve is not expensive---it's priceless"
03-03-2012, 03:23 PM #10
Other than scouring a system and possible TXV screen stoppage with the resulting scale, what inherent problems do you speak of my friend?
What is PVE?There's no such thing as normal,Just different kinds of crazy..
03-03-2012, 03:31 PM #11Moisture issues and hydrolysis.
Originally Posted by CRussell1975
PolyVinyl Ether oil.
03-03-2012, 06:59 PM #12
Okay, I guess I'm at the back of the class as well. Never heard of PVE.
The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
03-03-2012, 07:31 PM #13
