Results 1 to 13 of 18
Thread: Hose Length
    Feb 2012
    Hose Length
    From what I've been taught....most manufacturers recommend adding 3oz of refrigerant for every 5 foot of piping added to a system.
    Would using 5 feet of hoses on your manifold gauges not screw up pressure readings since technically you added 5 feet to the system making it short 3oz of refrigerant?
    Quote Originally Posted by AStudent
    Not if you remove the hoses.
    You've then removed the excess "piping"
    Feb 2012
    Sorry guess I should specify...would it not screw up the pressure readings on your manifold gauges while you are testing a system?
    Or is it not enough of a change to matter?
    On a small, critically charged system, it can.
    This is why we never hook up to critically charged systems unless your positive you have a refer issue. Also probably why alot of critical system don't have access ports...
    Quote Originally Posted by mjm88 View Post
    Exactly
    Sent from my HTC Sensation 4G using Tapatalk
    Jan 2010
    On critical charged systems i don't use hoses to check pressures.
    Also it depends on how one sets there scale when charging.
    Jan 2010
    [QUOTE=AStudent;12608871] manufacturers recommend adding 3oz of refrigerant for every 5 foot of piping added to a system.
    Are you talking 5' of liquid line add 3oz. ?
    Feb 2012
    [QUOTE=VTP99;12610151]
    Quote Originally Posted by AStudent View Post
    I believe it should specify in the installation instructions what the manufacturers recommended tubing length is, and how much refrigerant to add per so many feet of tubing added past that.
    Feb 2012
    That should be total system length not just the liquid line.
    What do you use?
    Jun 2002
    south jersey
    Just the gauges with fittings.
    You need to put the phone down and get back to work!
    Jan 2010
    Quote Originally Posted by jnsrose View Post
