Results 1 to 9 of 9
Thread: Trane VariTrane
    Hampton Roads, Virginia
    Trane VariTrane
    Hi Guys,
    I know this is not really a controls questions, but we controls guys probably have more info on VAVs than most mechanical guys. Has anyone got any infomation on a Trane box Model# HRB06GXF. The tag calls it a VariTrane Variable Volume Unit, but the guy who has looked at it says that it does not have the usual VariTrane Air Valve, but some linkages and springs. If anyone has any cut-sheets, IOM or anything on these units, can I please get a copy.
    Kevin
    EDIT: It is a pneumatically controlled box.
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    Dec 2006
    Hartford, Connecticut
    Those look like some very old boxes. Checkout the pdf’s I have hopefully they will have what you are looking for.
    That looks like it, check out the drawing on the linkage on page 11 in the DS-VAV1 file, never seen a VAV control like that before.
    Thanks twisted pair
    Kevin
    Apr 2005
    Boulder,CO.
    I looked for parts years ago and they were obsolete then try the roundin round out for a replacement if you have the room.
    Jan 2003
    Funny I just finished a project with a few of these dinosaurs on it.
    That spring in the linkage was a total PITA. We used linear actuators from Belimo to replace the pneumatic. The problem we ran into is, if the damper is running near closed the spring in the linkage can allow the dampers to bang around.
    Looking this over it would seem the site is more cobbled together than I originally thought. Most of the boxes had been replaced with only a handful of these guys still standing. At a quick glance these boxes with new ones may have its own issues....
    Thanks for the info!!
    Where the hell did you get these docs?
    Dec 2006
    Quote Originally Posted by orion242 View Post
    I have a large information vault……. And I had to go deep inside to find these.
    Funny thing is that these VAV boxes were made in the mid 1970’s. I was probably in Kindergarten when those documents were originally published.
    The Trane Round In / Round Out retrofit is a really nice product. It is well built with heavy gauge sheet metal and overall I think it is better than some of the regular VAV boxes out there. It is tricky to find the right retrofit application where you have the distance to install them. I think you need somewhere around 18” - 20” inches on the inlet of the box.
    The only issue I see with retrofitting a VAV from the 1970’s is why not just replace it. I would think the acoustics, air leakage and condition would warrant a replacement at that age. Certainly the cost would be more as there is additional labor and duct work required, I just wonder what the useful life of something like that is. If it is fan-powered or has electric or hot water reheats, I would think there are more efficient fans and the coils would be ready to be replaced. It is largely just a sheet metal box but nothing last forever. I wonder what the inside lining looks like after 40 years, must be a little bit of dust accumulation.
    Aug 2012
    Varitrane HRB08MXG: Looking for IOM, cut-sheets, submittals, etc
    I am new (both to posting and to this site) so please bare with me. The lab has some very old pnuematic Trane VAV controllers. The tag says use document VAV-IN-5 for calibration instructions.
    I tried to find this VAV-IN-5 on the internet and at Trane's website but no dice. Does anyone have this document and any other literature that explains/shows how these boxes work and how to set them up properly? The VAV-IN-1 in the original thread below is similar but a bit different.
    Thanks,
    Dale
Size:  42.0 KBName:  IMGP5552.jpg
    Jan 2017
    s# R95G74595 Model# VFPE17BSCG1DD
    do you have a catalog for defining the serial number for varitrane? thanks
    Jan 2017
    how can i define the age of trane product using serial number?
