Results 1 to 13 of 25
    Oct 2011
    scroll compressor
    I wanna verify if my train of thought is right or get slapped w a no lol
    I went to a service call complaint of a noisy outdoor unit. It was a trane heat pump w a scroll compressor. We checked the amps on it and it was running at 13 out of 18 amps w 40 degree outdoor temp. We thought it was high and that it could be a bad compressor. But when we attached our hoses we found the system was flat out of refrigerant.
    Normally I was under the impression that overcharged = high amps, low charge = low amps.
    But in this case, is it cus the system had no refrigerant and that the scroll compressor is suction cooled and that by not cooling the compressor it gave us a high amp reading?
    New Jersey
    you were pumping air most likely
    “If I have seen further than others, it is by standing upon the shoulders of giants.” ~ Sir Isaac Newton
    I'm learning all the time, the tombstone will be my diploma!!!
    Did you ever stop to think, and forget to start again?
    You would have seen pressures if you were pumping air.
    How low do you want the amperage to go?
    New Jersey
    if its flat out of refrigerant you can bet your butt it's pumping air
    Oct 2011
    I would have expected somewhere at or below
    50% of the dataplate so somewhere around 8-9 amps.
    But am I right to think that the compressor not being cooled, due to practically zero refrigerant, causes "high" amps?
    Oct 2011
    Or is it just the compressor pumping air that led to a 13/18 amp reading?
    New Jersey
    Quote Originally Posted by coronachris0711 View Post
    i would expect about 50% as well
    i dont think the lack of cooling would drive the amps up as much as you had
    there may be a bunch of moisture in the air your pumping that is contributing to the amp draw, and/or you could have a low megohm reading that would contribute to the high amps as well
    checked your gauges lately?
    did you megohm the compressor?
    Oct 2011
    Quote Originally Posted by Tommy1010 View Post
    Ok awesome. It def did have moisture because a leak point was evident. And Yup we did check our gauges.
    But no, we didn't megohm. I don't know what that is
    New Jersey
    Oct 2011
    Awesome, so this tool checks for a "partial short" to a deeper level? I appreciate ur help and the link (it has good info, just printed it out to keep!)
    New Jersey
    don't know if they covered this in the link but;
    a megohm reading is will indicate the condition of the winding insulation
    and/or it will indicate if the systen is acidic
    after a megohm reading, if the reading is low, it must be determined whether the "low meg" condition is due to winding degredation or just acid
    acid can be cleaned up, degraded winding insulation is permanent damage that can not be fixxed
    some techs "think" megohming is just for trending, it's not just for trending/tracking winding condition!
    Feb 2012
    san pedro ca.
    How long has it been running flat? I would be concerned with where and how big the leak is before worrying about amp draw. Compressor probably has already been damaged.
    What damage would running without refrigerant cause?
