Results 1 to 12 of 12
    cocoa, fl
    RTAA ice build complete
    I have an RTAA that when commanded to start ice build mode immediately goes to ice build complete. My entering and leaving temps are well above set point so it's not a sensor problem. HELP!
    MEXICO
    because they give more information?
    cocoa, fl
    "because they give more information" what does that mean? Was your response cut off?
    MEXICO
    more information about the machine? temperatures? etc.
    cocoa, fl
    EWT-37 DEG, LWT-34 DEG, ICE BLD COMPLETE 24 DEG. COMMAND CHILLER INTO ICE MODE, PRIMARY PUMPS COME ON, VALVES OPEN, CHILLER HAS NO ALARMS BUT DISPLAY GIVES CODE A101 ICE BLD COMPLETE. VERIFIED TEMP SENSORS, VOLTAGE FOR COMMAND, PUMPS, VALVES AND FRONT END STPT.
    MEXICO
    what is your set point? in what way this machine? auto, local or tracer?
    cocoa, fl
    Ice termination set point is 24F. Supply & return glycol temps are in mid 30's F. Unit is in Local mode.
    MEXICO
    mode of the machine, change it to ice machine, check the configuration of the machine
    MEXICO
    what's your email?
    your contacts that INITIATE ice building are opening after they close. I would recommend that you investigate the BAS that is controlling this feature. take a jumper and...wait...investigate first.
    any diagnostics?
    East of big city prices.
    Quote Originally Posted by jayguy View Post
    any diagnostics?
    I was thinking the same thing.
    Aug 2009
    Prattville, Alabama
    He said in post #5 that "chiller has no alarms", but people unfamiliar with this panel have been known to get confused on how to check for current alarms and alarm history. Come to think of it, so have people who are (supposed to be) familiar with it.
