Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 74
  1. #40
    north suburbs of Chicago
    A whole batch of comments here on why the thing is wet. Who cares if it's wet? Sure blow back, bad drains and all types of thing can cause that. It's a coil! It gets wet. Plain almost distilled water is not going to cause galvanized metal to rot out that fast! Look at the way that copper piping is discolored as well. This is just not the normal patina copper takes on in time.
    There is something in the airstream (probably from the home itself) that is reacting with that water and turning it corrosive. I think of a few beauty shops I worked on years back when hair sprays had propellants that would rot the hell out of steel heat exchangers using inside air for combustion.
    Even the worst pos galvanizing job on that coil would not account for the way that copper looks.
  2. #41
    Dec 2011
    bedford ind
    Home owner may have sprayed it with a home made remedy and didn't rinse it
  3. #42
    Dec 2011
    bedford ind
    It just came to. Isn't that a goodman coil!
  4. #43
    Jan 2011
    Massachusetts
    Where I am I've brought samples to a lab scrape the coil and gathered the material lab will tell you if chemical,what it is and where it likely came from if you do it any other way your just guessing test cost about 100.00 to perform
  5. #44
    Virginia
    Quote Originally Posted by ironpit View Post
    easy there there are some touchy people here
  6. #45
    Jacksonville, FL.
    Funny man!
    But, no, it's a Carrier coil; I can tell by the way it's designed.
    WHY?
  7. #46
    Myrtle Beach, SC
    Quote Originally Posted by Saturatedpsi View Post
    I'll be the odd man out here. How about the possibility of cheap sh*t ?
    That is a Lennox coil. Not cheap. Carrier has a colder inlet & flare outlet on their txv. Goodman uses the same txv, but it is adjustable, that one has fixed superheat.
    Remember, Air Conditioning begins with AIR.
  8. #47
    Dec 2011
    bedford ind
    He should just cut his losses, sell it as a "NEW" goodman and buy another coil! I'm so funny!
  9. #48
    Feb 2012
    Nebraska
    definitely a Lennox
  10. #49
    Myrtle Beach, SC
    Quote Originally Posted by Kevin O'Neill View Post
    Should have said Carrier has a SOLDER inlet, not colder. OOPS.
  11. #50
    Mar 2009
    Mount Holly, NC
    Quote Originally Posted by gantandbrown View Post
    It is a horizontal attic mounted unit. Brand new coil with receipts. Properly sized ducts, etc. The house had very high humidity. I was thinking that was the only cause of the issue, but the return is close to the bathroom and kitchen so I think the ammonium suggestion could have played a large role.
    first...
    why does the house have high humidity?
    there is a lot of rust and copper oxide, is the system oversized? what are the system pressures? temps? what is feeding the airstream? gas furnace? how's the flue?
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
  12. #51
    SE Michigan
    Is the home occupied by liberals? Their words can be very corrosive ya know.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
  13. #52
    Dec 2011
    bedford ind
    ooohhh! GOOD THOUGHT!
