Thread: IQ prestige honeywell stat
02-26-2012, 08:16 PM #1
- Feb 2012
- 15
I have a question about change over from heat pump too aux heat and back once temp drops too set point example, 75 degrees the stat says waiting for equipment and temp drops another 2 degrees before it comes on. is this normal for this stat i had a vision pro 8000 and this did not act this way.
02-26-2012, 08:51 PM #2
- Feb 2012
- 15
I have a question about change over from heat pump too aux heat and back once temp drops too set point example, 75 degrees the stat says waiting for equipment this stays on for about 20 min. and temp drops another 2 degrees before it comes on. is this normal for this stat i had a vision pro 8000 and this did not act this way.
02-26-2012, 08:54 PM #3
Something is not right.
02-26-2012, 11:31 PM #4
Professional Member*
- Dec 2011
- PA
- 98
