Thread: HRV Turns on AC
02-25-2012, 03:32 PM #1
New Guest
- Feb 2012
- 1
HRV Turns on AC
How can I prevent my HRV from turning on the Air condtioner?
The HRV has a relay to turn on the furnace fan. The N/O contact is wired to the furnace conrtrol board on the Red (24 Vac) and Green (Fan). This works well.
The thermostat is also wired to these furnace contacts along with a yellow wire for the A/C.
When the HRV energizes the Green to turn the furnace fan on, the thermostat also energizes the yellow / AC.
Do I need an additional relay to prevent the HRV from turning on the A/C?
Thanks!
02-25-2012, 04:06 PM #2
Often when you put voltage to G, it feeds back through the stat to Y. Someone with electrical control knowledge needs to study the HRV wiring and come up with a solution.
02-25-2012, 04:13 PM #3
Like baldy said, often the t-stat has a common terminal for Y + G. This is most common on the older t-stats. It'll take someone on scene who knows wiring to get it right and it may require more controls than what you already have. Or not, depending on different wiring options.
