    Jan 2012
    Heat loss/gain software
    Does anyone have a suggestion for a good heat/gain calculation program?
    Dec 2011
    Northwest Georgia
    You should buy ACCA manual j and become familliar with the calculation before using any software. That being said, i use wrightsoft.
    Everyday is like my first day!
    Massachusetts
    You can purchase the load calculator on this website for short money. It's not approved ACCA but it gets close enough for amateur calculations. For professional load calcs there are two primary programs. Wrightsoft and Elite. We use Wrightsoft and have for many, many years with excellent results but the cost of entry for the full system is a choker. You can start with fewer modules and work you way up as time goes on if you choose. I have no experience with Elite except to know it too is ACCA approved.
    Jan 2012
    Thank you....I will check them out
