Results 14 to 21 of 21
    MN
    There's more than moisture leaking around that flue pipe. It looks like I can see daylight up inside the hole? Maybe some new form of make-up air? Or possibly dilution air for the combustion products that are surely entering the house?
    Feb 2007
    Central NJ
    well, he can't SEE CO, so it won't harm him, right????
    You have to pay your due's before you pay the rent!
    Chester County PA
    There's no telling from the pictures, I hope that the other vertical copper pipe painted to match the walls, with the flexible copper water pipe threaded to it, is not the natural gas supply...
    It seems to be in an awefully peculiar location and looks to be headed towards a gas valve....
    ~smoke~
    "That motor's done, he let the factory smoke charge out!"
    MN
    Quote Originally Posted by smoke View Post
    ~smoke~
    Holy crap! Didn't even notice that! Good eye smoke.
    St. Paul MN
    I thought duct tape fixed everything? Electrical tapes seems to work too!!
    Quote Originally Posted by SinCityKid View Post
    Hahaha you funny. I was invited "through" the house to see about a possible job out back. I don't know how it is where you live but if I stop in the house and start putting my wrench on his equipment without consent I'm likely to get a boot to the ribs.
    There is no job in the back that would have been worth me turning a blind eye to that death machine. I always use the litmus test "How would I explain it to the Judge!"
    They will soon forget how long it takes, but they will always remember the quality.
    S.E. Pa
    Cool
    We don't have enough info. or another pic of that copper line on the right so we could only guess, which would be worthless. It does have a compression fitting which is not approved for gas nor is copper flex but then again, very few gas lines use or approve of soldered copper. Also, the gas usually comes in on the left.
    I think its another goofy water line. Note the shower-type stop valve in the wall behind the WH. What in the world does that control? More pics would be very interesting.
    Feb 2012
    Chile
    In our province, you'd be obligated to redtag it and warn the utility. Anything happens after you have visited the property, your behind is on the line as you were the last technician to observe the dangerous condition. At best you get your licence pulled. Of course, a bit of diplomacy makes the HO grateful for potentially saving his life as opposed to being pissed off for taking away his heat.
