Results 1 to 13 of 15
    Feb 2012
    Recommend a non-clicking thermostat
    Recently purchased a new home with a Honeywell FocusPRO 6000. The clicking is really annoying when the air powers on. Tried to get used to it but I can't so I want to swap it out.Was hoping for a recommendation on a solid state relay. Ideally it would be great if it used the same backing plate as the Honeywell, but I think none of the Honeywell are solid state.
    Been looking at the Venstar T1010 and Totaline P374-1700. Can't really tell the difference between the two.
    My requirements are backlit display.. and that's about it. I've had programmable in the past but usually just use override to keep it at the same temp all day/night. Needs to be RCYWG
    Also does the Ritetemp 8022 have a solid state relay? That is what I used to have in my old house and I can't remember it ever making a clicking noise.
    Thanks in advance. Really a newb to HVAC but tried to do my research before I asked questions here.
    Honeywell IAQ - absolutely silent.
    Feb 2012
    A bit pricey compared to the others I mentioned which were like $
    burlington county n.j.
    Quote Originally Posted by jbrotheim View Post
    like everything else...... you get what you pay for.
    Feb 2012
    True, but I will probably not even use the programmable portion.
    Southeastern Pa
    "Silence is Golden."
    I'd expect to be paying some Gold for it.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    if your looking to be cheap about it slap a remote sensor in place of the stat & put the stat in by the unit. can't say id do it that way but its cheap & will work
    Sent from my HTC Sensation 4G using Tapatalk
    Virginia
    What type of system do you have
    Northeast Ohio
    You do get what you pay for.
    DEM
    Float'N Vally, MS
    I want, but I am not willing to pay....
    Next
    Life is too short, Behappy!
    TFMM
    Feb 2012
    Quote Originally Posted by behappy View Post
    Next
    All I'm looking for is a solid state relay stat. I found a few that were $*** and under and just wanted opinions on them. Don't think that was really asking too much.
    Pricing not allowed.
    Thanks,
    Mod
    Aug 2011
    Lewes, DE
    have you tried the blue wire nut approach? very quiet...tho more difficult to use...
    Cincinnati, Oh
    Quote Originally Posted by Gross View Post
    light switch is the next step up in ease of use I believe.
    "Just get it done son."
    Dad adjusted
