Results 14 to 17 of 17
    Sep 2009
    Arnold mo
    I didn't go through the thread to see, but if the house has siding and the time comes to replace it, it would be a good time to look into exterior insulation at that time.
    An answer without a question is meaningless.
    Information without understanding is useless.
    You can lead a horse to water............
    http://www.mohomeenergyaudits.com
    Dec 2011
    Hiram, Ohio
    The exterior currently is plywood, tyvex, vinyl siding. If the time ever comes to re-side, I will certainly add insulation.. We had our old house re-sided, and the contractor used a wrap and a half-inch insulation board, wow, what a difference! (that house was built in 1930)
    So based on this latest thread (and the assumption that I did the measurements correctly, etc) should I be pretty good with going with the 80k modulating furnace? Any other thoughts? Thanks, Mike
    Should be ok.
    Dec 2011
    Hiram, Ohio
    thanks guys. I feel better about this since I did my own calcs. Now at least if it turns out wrong I can blame myself, I like to take responsibility for things.
