Results 1 to 8 of 8
    Apr 2006
    Looking at putting a new roof on the house after 15 years. Looking at replacing the original asphalt shingles and considering a metal roof. Have seen studies comparing metal to shingles which indicate a possible effect on the heating and cooling requirements. What are your thoughts?
    Jul 2002
    Zelienople, Pa
    There will be an effect.
    Run a Manual J with asphalt shingles vs. metal roof and post your findings...
    Huntsville,AL
    depends upon:
    type of paint used
    color of paint used
    seperation between roof & sheating
    attic ventilation
    type of sheating
    amount of shading
    roof orientation with respect to north
    Manual J 8th addition
    Category 16CR-38
    "Under attic or knee wall, Vented with Radiant Barrier, Dark Asphalt Shingles or dark Metal, Tar and Gravel or Membrane, R-38 insulation"
    The contributing factors are vented or unvented, Radiant barrier or No Radiant barrier, Dark or light color, and R-value.
    If you are replacing a dark asphalt shingle with dark Metal, Manual J load calc will not change.
    Tile or concrete will change your load.
    No difference on type of roof, it's the insulation in the attic that will save money.
    Majormickey--I can assure you the type of roof makes a world of difference as to how much radiant heat, in summer, is transfered to the insulation below.
    Apr 2006
    The reason I asked was prompted by the following study:
    http://www.fsec.ucf.edu/bldg/baihp/c...roof/index.htm
    SW FL
    "Initial results for a nine week period in the summer of 2005 show the white metal roof providing a 19% savings in air conditioner energy over the same period in 2004"
    I believe that the 2005 temperatures in the subject area
    were > than in 2004.
    FSEC and a few other building sources provide
    VERY Reliable, well-documented studies.
    Designer Dan
