Results 14 to 26 of 48
    Feb 2012
    utah
    all right, maybe i need to spend some more time searching and maybe i'm asking this in the wrong place. I called my local trane guys (slc) and the first thing they tell me is that the slide valve is not rebuildable, so i give them the SB # and then they tell me that the rebuild kit is no longer available. the guys in slc are good guys obviosly just not familiar with this problem. so i quess what I am asking is if anyone has a part list they can send me. thanks. chhb100tka0r119ahnn
    ottawa canada
    And guess what .....there correct , it isnt feild rebuildable .
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    The Hot South
    The slide valve is not rebuildable in the field but that's not your problem. The piston is more than likely your problem.
    Oct 2011
    La.
    This is a tossable compressor like all small screws. They are just not worth the expense to try and fool with. York DX compressors had problems as well with the slide valve, they had a rework that would work sometimes and sometimes not. Just saveyourself the headaches and get a new compressor.
    Sorry I know that is not what you want to hear.
    ottawa canada
    Quote Originally Posted by spinning wheel View Post
    So you would change the compressor just because it has a burnt unload solenoid, or a blocked pill filter ??
    Good call ,,,, are you on commission for selling parts ?
    The Hot South
    That statement is simply not true. There are many relatively inexpensive repairs that can be easily made on these compressors. The slide valve piston rebuild is a 4 hour job and the parts are minimal, $XXX.XX. A new compressor is $XX,XXX.XX.
    ottawa canada
    Only if the nut on the piston end of the shaft comes undone , if it unscrews at the other end .....your screwed , then its a whole different ball game ...been there done that .
    The Hot South
    Quote Originally Posted by Healey Nut View Post
    That's true.
    Dallas ,Texas
    So what does this guy do?
    UA 100
    It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
    ottawa canada
    Quote Originally Posted by thegoodlistener View Post
    Call a Trane guy
    Oct 2011
    La.
    Which one is it healy, rebuildable or not. You are kind of contradicting yourself here. One post yes, the other not.
    ottawa canada
    And the contradiction would be ......where ?????
    Slide valve ...not feild rebuildable
    Piston slide valve ...feild repairable
    The Hot South
    And if the nut at the piston end does not come undone, it's still servicable but
    more of a PITA. There is a SB on that.
