+ Reply to Thread
Results 1 to 20 of 48
Thread: trane rtaa slidevalve
Previous Post Previous Post   Next Post Next Post
    Feb 2012
    utah
    while i have read this forum for years I have never actually talked to any of you, still thanks for all your insight. A few months ago I read a link about slidevalves on rtaa sticking, thus causing a high current overload on startup. has anyone ran into this before and if so what was the fix.
    Feb 2012
    EVERYWHERE
    Have you checked everything? It could be a bad unload solenoid, a leaking lip seal, a leaking load solenoid, or a stuck piston. So have you verified that it is a stuck piston.
    The Hot South
    Nique, welcom to the forum!
    This subject has been talked about numerous times so I don't think a new thread needs to be started. Just search "RTAA slide valve problems" or "RTAA oil flow problems" and you'll get all the info you need.
    Mar 2012
    montreal/canada
    What size of tonnage is ur compressor
    i will speak on behalf of Graham...
    AAAAAAARRRRRRRRRRGGGGGGGGGG!!!!!!!!
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
    ottawa canada
    Quote Originally Posted by jayguy View Post
    Tks Jay . I cant believe that this subject just keeps on coming up over and over and over again and 99% of the time the fix is staring the tech or techs in the face but they just dont see it .
    I"m not a service tech, I’m retired ….I used to be a thermodynamic transfer analyst & strategic system sustainability specialist
    East of big city prices.
    Quote Originally Posted by Healey Nut View Post
    Nut do you have any tips for the newbies to use for the search feature? TIA
    ottawa canada
    Quote Originally Posted by thegoodlistener View Post
    Just like some have already said . RTAA slide valve and oil flow diagnostics in the keyword search . thats what the keyword search is for ...it aint rocket science .
    Mar 2012
    montreal/canada
    Aaaaaaaaaaaarrrrrrrrrrggggggg
    Feb 2012
    utah
    wow do I sense some frustration, so I spent a couple of hours searching and found all the info I needed plus some. I will be replacing the "puck" in the next couple of days. So thanks for getting me on the right track.
    Quote Originally Posted by nique View Post
    wow do I sense some frustration...
    this is probably one of the most (definitely top 10) asked questions on the commercial section...anymore, the number 1 answer is to use the search.
    Feb 2012
    utah
    all right, maybe i need to spend some more time searching and maybe i'm asking this in the wrong place. I called my local trane guys (slc) and the first thing they tell me is that the slide valve is not rebuildable, so i give them the SB # and then they tell me that the rebuild kit is no longer available. the guys in slc are good guys obviosly just not familiar with this problem. so i quess what I am asking is if anyone has a part list they can send me. thanks. chhb100tka0r119ahnn
    ottawa canada
    And guess what .....there correct , it isnt feild rebuildable .
  14. #14
    So what does this guy do?
  15. #15
    ottawa canada
    Call a Trane guy
  16. #16
    Call a Trane guy
    I'm gonna doubt that happens. Your kinda splitting hairs on the terminology of a slide valves repair. Plus according to this guy they say the repair kit is NLA.
  17. #17
    The Hot South
    The slide valve is not rebuildable in the field but that's not your problem. The piston is more than likely your problem.
  18. #18
    Oct 2011
    La.
    This is a tossable compressor like all small screws. They are just not worth the expense to try and fool with. York DX compressors had problems as well with the slide valve, they had a rework that would work sometimes and sometimes not. Just saveyourself the headaches and get a new compressor.
    Sorry I know that is not what you want to hear.
  19. #19
    ottawa canada
    Quote Originally Posted by spinning wheel View Post
    So you would change the compressor just because it has a burnt unload solenoid, or a blocked pill filter ??
    Good call ,,,, are you on commission for selling parts ?
  20. #20
    The Hot South
    That statement is simply not true. There are many relatively inexpensive repairs that can be easily made on these compressors. The slide valve piston rebuild is a 4 hour job and the parts are minimal, $XXX.XX. A new compressor is $XX,XXX.XX.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
