Page 1 of 4 1234 LastLast
Results 1 to 13 of 48
    Feb 2012
    utah
    trane rtaa slidevalve
    while i have read this forum for years I have never actually talked to any of you, still thanks for all your insight. A few months ago I read a link about slidevalves on rtaa sticking, thus causing a high current overload on startup. has anyone ran into this before and if so what was the fix.
    Feb 2012
    EVERYWHERE
    Have you checked everything? It could be a bad unload solenoid, a leaking lip seal, a leaking load solenoid, or a stuck piston. So have you verified that it is a stuck piston.
    The Hot South
    Nique, welcom to the forum!
    This subject has been talked about numerous times so I don't think a new thread needs to be started. Just search "RTAA slide valve problems" or "RTAA oil flow problems" and you'll get all the info you need.
    Mar 2012
    montreal/canada
    What size of tonnage is ur compressor
    i will speak on behalf of Graham...
    AAAAAAARRRRRRRRRRGGGGGGGGGG!!!!!!!!
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Mar 2012
    montreal/canada
    Aaaaaaaaaaaarrrrrrrrrrggggggg
    ottawa canada
    Quote Originally Posted by jayguy View Post
    Tks Jay . I cant believe that this subject just keeps on coming up over and over and over again and 99% of the time the fix is staring the tech or techs in the face but they just dont see it .
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    Dallas ,Texas
    Quote Originally Posted by Healey Nut View Post
    Nut do you have any tips for the newbies to use for the search feature? TIA
    UA 100
    It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
    ottawa canada
    Quote Originally Posted by thegoodlistener View Post
    Just like some have already said . RTAA slide valve and oil flow diagnostics in the keyword search . thats what the keyword search is for ...it aint rocket science .
    Not in Iran
    Thumbs up c what I can do
    yea., ok try the search link
    click button.,
    input keyword
    rtaa slide valve
    click ok or search.,
    c what comes up.,
    read.,
    perform work.,
    dont jack up.,
    if soo ., oh., si^*&(%
    or look here _____________
    Attached Files Attached Files
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Not in Iran
    Post oh
    i was looking for my SB4
    i cant find in my libary., oh well
    anybody want to take effort and email so i can add
    thx
    Feb 2012
    utah
    wow do I sense some frustration, so I spent a couple of hours searching and found all the info I needed plus some. I will be replacing the "puck" in the next couple of days. So thanks for getting me on the right track.
    Quote Originally Posted by nique View Post
    wow do I sense some frustration...
    this is probably one of the most (definitely top 10) asked questions on the commercial section...anymore, the number 1 answer is to use the search.
