    Apr 2006
    dayton, ohio
    Smile
    Where to go on line and down load for 13 seer and up?
    to the manufacturers website.
    Depends...
    You have to ask the manufacturer of the system
    Superheat and subcooling depends on:
    1. The pressure within the system (after compression for subcooling, and after evaporator for superheat), and
    2. The refrigerant used,
    Not SEER or EER.
    Sorry, can't be of much help
    Apr 2006
    dayton, ohio
    superheat/subcooling charts
    Maybe I put this question out there wrong. If you do not have access at the time you are looking at the unit, there is a chart for captube/piston metering for correct superheat ranges, some are located in cycle diagnostics reference books. I was give one awhile back when 13 seer came out, because of the diffence in suction pressure. I know I can buy a palm with all the differnt gases superheat/subcooling information, just trying to get some free information.
    You should be able to get those charts from your distributor.
