Results 1 to 13 of 14
    Mar 2002
    Concord, CA
    I've heard all the bad ideas. I've got a piece of painted plywood in the window to my right even as I type this. But I'd never do that for a customer because of the lack of security, poor insulation, etc. Has anyone ever seen a good way of filling that gap?
    Valdosta Ga
    Hmm
    Duct board spray painted
    Senior Tech Guest
    A glass pane with frame.
    Jul 2002
    St Paul, Minnesota
    You're right, ST, worked for me once. Relatives house and I went to the ReUse store and got an older window in good condition, trimmed it a little and painted the double window exterior. New window sat above the window shaker and the window next to it was a combination but the paint made it look almost custome made. Stays in all winter by covering the a/c outside.
    Rapid City, SD
    Well, the one I put in my bedroom I just close the window on, it has the "wings" that expand on each side and somewhat cover the window opening. The remaining gaps I take an old towel and wad up in them.
    Not bad for an HVAC guy eh?!
    chicago suburbs
    i think some butcher uses Vulkem to seal............
    FILL OUT YOUR PROFILE!!
    Jul 2002
    St Paul, Minnesota
    Don't think you got the picture.
    filling the gap above a window AC on windows that slide left/right?
    Apr 2003
    Are you installing a "casement window a/c"?
    Installation Instructions
    Florida
    I would use 2 aluminum strips. Do the inside first, fill with insulation(great stuff) and then outside strip. Attach with small alum. self tappers.
    Rapid City, SD
    You'll have to forgive me, I wasn't really giving a good reply as in how to fill in the gaps.... just how I hacked something together for mine. Sorry for the confusion
    Jul 2002
    St Paul, Minnesota
    No problemo, and by this time there is probably a huge picture of C. J. Jones installed above the a/c.
    Mar 2002
    Concord, CA
    Thanks for the replies guys.
    Why is there a gap? Can you bring the sliding
    window down to the top of the A/C?
    This was my business, so I can tell you how
    they did it on Miami Beach. There is no reason
    why plywood cannot be can't be made secure.
    A window with a window unit in it is really
    never going to be truly secure. Make sure
    the unit has a good downward pitch toward
    outside.
    Ductbaord will give you less security, but you
    could add ductboard to plywood for insulation
    purposes. Note: plywood has more insulation
    value than glass.
    Cheers,
    Michael
