Results 1 to 13 of 19
    Jan 2012
    WEST COLUMBIA S.C.
    condenser air temp.
    On a 90 degree DAY,should the discharge air from condenser fan be 30 degrees above ambient temp.(120)Anything less would mean dirty outside coil? True or not.
    Jan 2010
    North Huntingdon,Pa
    In the ball park,depends on a lot of variables...
    PA#9377
    Your Satisfaction...Our Goal.
    Hewitt,
    Please start threads for tech questions in the tech-to-tech area.
    Jan 2012
    WEST COLUMBIA S.C.
    Hewitt,
    Sorry. Still getting use to site.Love it
    Feb 2012
    Alabama
    Quote Originally Posted by hewitt View Post
    The more dirty the coil is the higher the temperature will be. 20 degree rise is considered ideal.
    Jan 2001
    Nebraska
    Chart that I Use.
    SEER
    TD Range
    8
    30 35
    10
    25 30
    12
    20 25
    13>
    10 20
    Jan 2012
    WEST COLUMBIA S.C.
    Has anyone seen the last reply.Has someone ever used this.I never seen this scale
    Jersey
    the scale to me sound about right. this is going off what I normally get. I use my pressure to let me know if my coil is dirty
    Ride hard on a Harley!!
    Jul 2011
    East coast USA
    when it comes to knowing if condenser coils are dirty, other than sight. Is to go by how the unit is running, SH, DT, pressures. If the unit is running as designed based on the running specs. cleaning a coil will not make it run any better. but as a rule 10 to 20 Diff. is what i have used as a quick check
    Feb 2012
    Atlanta, Ga
    30* for r22 and 20* r410a?
    Quote Originally Posted by alex13177
    Refrigerant doesn't matter.
    Feb 2012
    Atlanta, Ga
    you are right, I was thinking something else. Brain fart!
    May 2011
    Ripley, WV
    openclasspro mentioned variables in that equation, some of them include: if you are maintaining a 68-70 Room temperature the OD coil temperature will be lower than if you just came home and had the system off and it was 80 inside. Also low air flow (dirty coil, filter blocked return, blower running too slow) can cause the OD coil to bee cooler than expected.
