Results 1 to 13 of 24
Thread: Double wall elbows
02-19-2012, 08:36 PM #1
Double wall elbows
He knew enough that it had to be 100% double wall, how many elbows can be installed in the connector? Otherwise average retrofit.
02-19-2012, 09:02 PM #2
Who ordered the flue makeup for the job?
"Just get it done son."
Dad adjusted
02-19-2012, 09:47 PM #3
- Feb 2006
- 507
is that furnace powered with an extension cord?
that can't be right
02-19-2012, 09:56 PM #4
Banned
- Feb 2012
- san pedro ca.
- 362
it's an appliance connector, I would have to say not a bad instal he probably didn't have a 1 ft. piece so he went with what he had. no excuse
02-19-2012, 10:27 PM #5
- Dec 2003
- 2,051
Looks okay to me. I beleive the vent tables have a note stating the tables are based on two elbows, and provide information to adjust the tables for additional elbows.
02-20-2012, 12:18 AM #6
unbelievably, it is.
members from arizona will back this up also.
It's a local code, and in some cases in that state, I believe it is required.
Other weird codes from the area (that I'm aware of):
The required usage of flex for a portion of the gas line.
Water heaters have to be X inches of the ground. (california I believe)
Water heaters have to be strapped to a wall in case of earthquake. (cali code)"Better tell the sandman to stay away, because we're gonna be workin on this one all night."
Dad adjusted
02-20-2012, 12:38 AM #7
Professional Member*
- Oct 2011
- Las Vegas, NV
- 347
Yea, most of the furnaces here in Vegas are powered off of a "pigtail" cord. When I first moved here, I was like wtf is that crap. But that's how they all are. All gas lines have a flex connector. All water heaters got to be off the floor and strapped to a wall with earthquake straps, also sitting in a drip pan.
Sent from my PG86100 using Tapatalk
02-20-2012, 12:29 PM #8
nice that the ac trap of right in front of the service door. Using a pigtail ext cord i personally do not like and the flex line just a quick easy way in and out to bad they didn't take more time to hard pipe etc. what a shame
If you can not do it right, Why even do it at all?
02-20-2012, 09:54 PM #9
02-21-2012, 05:10 PM #10
Pipe is pipe...he used what he had. Do you really "order pipe" per change-out? Really? B-vent is a bit$# to make up most times anyway....far from the worst I've seen.
02-21-2012, 05:14 PM #11
the control wire looks like sh!t. i.m.o of course. I'm not a fan of wrapping it to resemble a phone chord
Sent from my HTC Sensation 4G using Tapatalk
02-21-2012, 09:24 PM #12
- Feb 2009
- Massachusetts
- 39
Throw a hanger on the elbow and the flue looks fine to me.
02-21-2012, 09:30 PM #13
- Nov 2009
- Bismarck ND
- 78
Whats the point of the trap on the evaporator, its on the positive side of the blower. Around this area they are never trapped on the positive side.
