Results 1 to 7 of 7
    Lehighton, Pa.
    Need opinions on Carrier Gas Furnace
    I am in the process of building a new home. The builders hvac guy told me he was installing a carrier 58mvco furnace. I went to the home today and the furnace model installed is model 59tn6a. Looking at carriers website, it appears that the unit installed has a slightly better efficiency rating.
    Did I get a better unit? Looking for opinions. Thanks.
    Massachusetts
    The Carrier/Bryant line is in the process of changing model numbers. The furnace your installer has put in is brand new in the Carrier line-up, is a 2-stage model with a full featured variable speed blower. Overall, a very nice furnace though it's not an Infinity model but then, neither was the original quote. Be happy with the change. He's not cheating you.
    Dec 2010
    It's too bad that you didn't get a chance to upgrade to the Infinity model. Then, in the future, you could have upgraded to a Infinity zone system.
    Lehighton, Pa.
    Based on Carriers site, Model 59tn6a is listed as: Infinity 96 New Edition, and Model 58mvco is listed as: Infinity ICS Modulating Gas.
    It appears that these are both from the Infinity series. Am I missing something?
    Dec 2010
    Quote Originally Posted by jeepgrady View Post
    I'm not fimiliar with the new model numbers. If it is the Infinity, then that's great.
    Note: Carrier used to make 2 differant controlers. The "base' Infinity control, not compatiable with zoning, or the Infinity control for zoning.
    Lehighton, Pa.
    Any other opinions?
    butler pa
    is the infinity control being included ? if not id add it to get the full benefits of the system
