Results 1 to 13 of 15
    Apr 2001
    Gas sediment trap inside the cabinet
    I have never seen it done this way. Its a horizontal furnace, with the gas line entering from above.
    Jason
    Cincinnati, Oh
    SIGH. Another GMH90110 hacked in.....
    "Just get it done son."
    Dad adjusted
    Oct 2011
    Harrisburg, NC
    I see you are in PA... that method keeps the trap from freezing any accumulated moisture
    At least they put one one it.
    I can't fix it if it won't stay broke..
    Jun 2011
    At least it has a trap! Lmao
    NJ
    It's called a drip leg.
    Cincinnati, Oh
    Quote Originally Posted by hvactechdan View Post
    some people like cucumbers pickled.
    Dad adjusted
    Dec 2006
    Litchfield,Il
    You know, its not normal but its not hurting anything. I get more aggrevated when I see unions inside the cabinet or a gas cock located 20' from the unit or none at all on fairly new installs.
    If your not getting the results you desire then change. People change from either desperation or inspiration.
    Ottawa, ON
    WOW
    Never seen that before at all. Somethings just make me wonder.
    I always put the dirt pocket on the outside with the union and shut off.
    Anytown USA
    Quote Originally Posted by luskys a/c View Post
    I get more aggrevated when I see unions inside the cabinet .
    I just ran into that on a unit heater I changed. It had the union and gas cock inside the unit. The building was located 200ft from the main building and had NO shut off for the secondary building that I could find. Good thing it was low pressure, I had to remove the gas pipe going into the unit and install a new gas cock on the fly.
    S.E. Pa
    Exclamation Read your gas code for proper terminology
    Actually, its not. It is called a "sediment trap". Look in your gas code. Drips are installed in the lowest point of the gas piping usually right inside the house from the meter and required only when you have 'wet gas'. Rarely required anymore. Now, everyone calls them "drip legs" or "dirt legs" but those are incorrect terms, similar to Southerners ordering a "Coke" when they want any brand of soda--generically speaking.
    The code does not prevent the installation of the trap from being located inside the cabinet but it is rather awkward. Cannot see it clearly but there must be a ground union joint so the unit can be disconncted and there must be a listed shutoff within 6 feet. As long as this pic is the actual orientation of the trap, it is acceptable.
    At least it is at the point of direction change. Amazing how many are in a horizontal run.
    Apr 2001
    This one splits the difference.
    Jason
    Nov 2007
    Sherman, TX
    Maybe the installer was short one 1/2 inch elbow, and came up with a creative solution....
    Technical incompetence is NOT a sales tool....
