Page 3 of 3 FirstFirst 123
Results 27 to 35 of 35
Thread: Nate senior
  1. #27
    Mar 2012
    West Chester, PA
    maybe you should look into that...
  2. #28
    Arizona
    Quote Originally Posted by ADillon View Post
    My fault it is only goof for 5 years but all of your other certs should be brought up to the same date as the senior cert. This from NATE's website
    Note: When the Efficiency Analysts Certification is earned the dates of all other certifications are updated to coincide with the EA. When recertifying in EA, all certifications are updated at the same time. If EA is not recertified the candidate must recertify in all other specialties. Also, note that holding HP and AC counts as one certification not two. Passing Senior Level Efficiency Analyst awards a 5 year certification.
    Someone needs to tell them that, here is the back of my card.. LOL
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
  3. #29
    Mar 2012
    West Chester, PA
    I proctor their tests and i can tell you that they aren't on top of anything over there. You will have to call them, if it's a concern. Which to me it would be considering how expensive the tests are and how many CCHs they want you to have inorder to re-up your certs.
  4. #30
    Jun 2012
    Northern NV
    NATE Senior test is open book
    Was taking some of the nate tests and noticed the "Senior Efficiency" test option. Just clicked on it and took it like the others, closed book. Got a 74% which is NOT passing. Still not sure what is a passing score on this'un. Looked into it a bit further and found it was open book!! Sheesh.... This is the first NATE cert I have not passed on first try and about 20 to 30 minutes of effort.
    THE book is the NATE "Reference Manual" and can be sourced through RSES.
  5. #31
    Quote Originally Posted by Juan Madera View Post
    Where did you find this test to take?
  6. #32
    Over 100 new views and no response.
  7. #33
    Jun 2012
    Northern NV
    The test was on the list of NATE tests that you could select while being proctored. It popped into the que after I had finished taking two of the cert tests. Being a bit cocky about having passed 7 of em already, I just jumped in and took the Senior level too. If I had had a psy chart i'd have passed. Again, did not know it was open book. You know the saying; "fools rush in where angels fear to tread."
  8. #34
    Mar 2012
    West Chester, PA
    I think you should be able to take it anywhere that proctors NATE tests
  9. #35
    Mar 2012
    West Chester, PA
    So I just took and passed this test too. You inspired me! Has anyone who has taken this test also taken the RSES tests? I wonder how they stack up to one another. I found this test to be more difficult than the other specialty tests.
