Results 14 to 26 of 29
Thread: Trane troubles
    is this a model that you can put your meter across a couple terminals and determine which mode the unit is in and if there are any alarms?
    the only things that would usually keep a blower off is smoke, freeze or un occupied setting?
    NC
    no. I have 24 volts across g & c coming into the rtrm board.
    looks like you have it figured out already?
    I will read some IOM stuff and look through the reliatel book!
    Feb 2011
    Sacramento, CA
    The Trane unit I was working on had the same symptom. I also thought it was the main control board at first, but after some reading I found that I had a faulty economizer board. I purchased a new economizer board and unit quickly come online.
    Feb 2011
    Sacramento, CA
    One way to test is to turn off the unit, unplug the economizer board plug from the main control board and then turn the units disconnect back on. If the blower comes on then replace the economizer board. The board costed us $$$$
    Jan 2012
    Central New Jersey USA
    The boards usualy have triacs (electronic switches) for the output relays. Can you remove the output wires at the RTM going to the fan output and see if you have 24 volts. If you have 24 volts at the board and lose the 24 volt when you put the wires back on, the triac is bad and you have to replace the board. Can this unit be viewed with Rover software and do you have Rover? As someone said earlier, the economizer or the connections may have a problem. If you still have the bypass plug for the economizer, you can try plugging that in and see if the fan starts.
    Good luck
    Southeastern Pa
    If the unit runs in TEST (including blower) the main board is good.
    In that case, it will be the econ board.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    he has said a dozen times!
    he has 24 volts across c & g!!!!!!!!!!!!
    Quote Originally Posted by timebuilder View Post
    true knowledge exists in knowing that you know nothing.
    if you check the diagnostics or on most of them
    ltb1-6 to ltb-9 etc you will see what mode and if there are alarms!
    that should tell you a lot!
    but it sounds like if you got 24 on c and g everything is perfect!
    Southeastern Pa
    Quote Originally Posted by supertek65 View Post
    He did.
    When someone says they did some tests on a Trane, I often think they may have removed wires from the contactor, and are reading through the snubber circuit. I would need more info to understand exactly what steps he has taken.
    I like to put the thing in test to see how it reacts. It can separate the sheep from the goats, and eliminate false readings you can get by looking at an output that has no load: showing a false reading.
    If C and G mean he is using a CTI, and C is common and G is fan, we can eliminate the main board as an issue by just stepping through test mode.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    LOL!!!
    you are correct!
    test mode tells you alot!
    He did.
    Southeastern Pa
    LOL!!!
    you are correct!
    That's why I like it.
    No resistor box needed. Just a jumper and a little patience!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    houston, texas
    If the unit fails to initiate the complete test mode, the rtrm or ucp whichever it has is bad. I have had some fail the test mode but reset the power and retry they worked. Trane tech support told me years ago if the board fails the test mode it's bad.\
    They will turn on the outputs no matter what. On the lennox units you can disconnect both the high and low pressure switches, put in test and the compressors will still come on.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
