View Poll Results: Which brand(s) of ducted residential HVAC Equipment do you currently carry
- Voters
- 83. You may not vote on this poll
American Standard
15 18.07% -
Bryant
9 10.84% -
Carrier
23 27.71% -
Goodman/Amana
20 24.10% -
ICP (Comfortmaker, Heil, Tempstar, Arcoaire)
13 15.66% -
Lennox
19 22.89% -
Nordyne (Maytag, Frigidaire, Tappan, Westinghouse)
10 12.05% -
Rheem/Ruud
18 21.69% -
Trane
22 26.51% -
Whirlpool
1 1.20% -
York
12 14.46% -
Other
14 16.87%
Multiple Choice Poll.
Results 66 to 78 of 140
04-22-2012, 11:48 PM #66
There was about a year where the louvers were too close to the coils and damaged the fins, but that has been resolved. I agree with the stripped out screws, but not a bad enough issue to hate the brand.
In my heat pump Frankensystem I am using a nominal 3.5 ton 13 SEER indoor Goodman coil with an Amana ECM blower section connected to a 14.5 SEER rated Luxair heat pump. It has been working really great for two years now, and I am still running it with a piston in the indoor coil. Go figure. Seems like some of us don't have the issues with brands that others have....
Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
04-22-2012, 11:49 PM #67
04-29-2012, 03:57 PM #68
we carry Lennox and York.....
04-29-2012, 04:13 PM #69
04-29-2012, 06:35 PM #70
In order from most to least; Lennox, Trane, Goodman, Carrier, and Rheem. Carrier is crawling back into the race with their 90% and multi-stage equipment. Used to carry York and Payne but phased them out.
Sent from my ADR6350 using Tapatalk 2
04-29-2012, 07:16 PM #71
We see a lot of old Amanas chugging along here.
I don't know for sure when they where purchased by Gooman, but we are replacing heat exchangers all the time on Amanas from around 1999 and newer. Some of them only 6 years old! I am down to an hour for an AMH, AMS or AMV HX changeout.
What is real nice (sarcasm), is the Amana came with SS heat exchanger, but when you buy a replacement under warranty it is just an aluminized.
04-29-2012, 09:35 PM #72
04-29-2012, 10:19 PM #73
Probably cause the SS process was why they were cracking or splitting or whatever is happening to them. Lennox began doing the same things with their coated Duracracks.
I probably have fifty Amana units from 20 years ago still running with the original inducers. The kind that needed Anderoil that seldom get oiled. IMHO one of the better 80% units ever made. Period.
04-29-2012, 11:19 PM #74
No, it isn't the SS part that fails. It is the hot side of the secondary, or recoup coil. Right where the tubular primary enters the secondary. The part that rusts through is the non SS part of the secondary. Notice all the flaked off rust. About 85% of them are 2 stage models, and 15% single stage. And about 70% are LP and 30% are NG. The NG and LP models fail in the same way and there is no noticeable difference between the two when you take them apart.
Two different conditions are contributing to this failure. One is the post purge is too short on the inducer motor allowing the corrosive flue gases to remain in the HX after post purge where they can eat the metal. Another problem is that they are badly underfired, for example a 90KBTU usually is only firing at 75K to 85K at factory settings. This allows some condensing in the hot side of the secondary, especially on the 2 stage models.
04-29-2012, 11:35 PM #75
Thanks for the info and pics.
04-29-2012, 11:42 PM #76
05-09-2012, 07:29 PM #77
Professional Member*
- Feb 2010
- NE Alabama
- 301
Iwoke up from a weekend of fun with a Rockin' B branded on my right rear cheek. Never figured out who did that.
05-09-2012, 08:08 PM #78
