Results 14 to 26 of 32
    Chicago, IL
    Quote Originally Posted by timjimbob View Post
    Looks like what I did last month.
    Customer had a side discharge RTU that needed replacement. Roof products salesman sold him a roof coating that was 6" thick and coated up to RTU panels. Pullung this would have left a huge hole on roofing.
    I told customer, let's leave it and put new RTU over duct-roof penetration.
    Whats wrong with that?
    I think the unit on the left is just sitting there. It was previously installed on the curb to the right, but they took it off and set it aside and put a new unit on.
    Feb 2012
    Centerville, Iowa
    Bad Jobs
    I'm sure you have all seen the pic of the compressor bolted to a piece of plywood outside the condensing unit and piped in? Works
    May 2009
    Put that in profit for you
    Jun 2002
    south jersey
    Boy get to cutting. There ia a couple hundred $$$ worth of scrap up there.
    You need to put the phone down and get back to work!
    Jan 2010
    The curb adaptor looks wrong. Can i have the old Lennox ?
    Feb 2012
    Looks like the vent is pointing down towards the fresh air intake on the left hand unit....you are still blowing hot air into the unit regardless of gas or electric causing the system to work harder.
    I'm not a tech so I may be way out in left field somewhere.
    Connecticut
    Is that an access door open on the unit on the right? In that case, there is a fine example of gravity cooling, the cold air dropping right down the return if that's the filter/blower section.
    Tom D. - Long-time Journeyman from CT.
    On account of being a democracy and run by the people, we are the only nation in the world that has to keep a government four years, no matter what it does.
    Dec 2009
    Quote Originally Posted by craig1 View Post
    BINGO!
    Feb 2012
    Looks suspicious indeed. Could it be that the owner of the building informed hvac/r contractor to leave it on roof so it could be seen by insurance, warranty company, other. Probably more along the lines of a couple of guys not feeling like rigging another unit that day. Could be that Helicopter received call to replace Donald Trumps Rooftop, WHO KNOWS, but as you know you've seen it all until you get to work today!
    Jan 2005
    where it's nice and warm
    Someone is hoping the copper vultures will pick it clean
    NJ
    Nothing wrong with leaving the old unit on site for spare parts...
    Apr 2010
    Ontario
    10 ton unit sitting on 5 ton curb.
    ENJOY THE RIDE
    Connecticut
    Is that a tornado prone area?
