Results 1 to 8 of 8
    Greece
    TRANE RTHC retrofit
    Hello all,
    On a flooded RTHC I want to rebuilt the electrical panel.
    Do you know if there is retrofit kit to use CH530 instead of UCP2?
    Thank you and best regards,
    CV
    Windsor ON Canada
    Try Micro Control Systems in Ft. Myers Florida. They can provide a controller to replace the UCP2.
    A land down under
    The UCP2 platform has not been superseded for aftermarket so I do not believe a retrofit kit is currently available for RTHC to CH530, however there is no reason the parts could not be individually selected and installed as a field engineered retrofit. IMHO
    Jan 2012
    Perth Down Under
    If you can find a flooded RTHC chiller please let Trane know"............ Cause they never built one. The RTHC was the first falling film chiller built by Trane and has the external economizer on it.
    I have never seen a replacement controller for these but what are the benefits to warrant the expense
    I don't know why you would need to do this, but if you really wanted to, you could piece the control panel parts together. You would also need at least 1 new EXV, and a new liquid level sensor. I don't think there is any way around that.
    Greece
    Dear all,
    Thank you for your answers and sorry for my English.
    By "flooded" I mean that the basement at which the unit is located was full in water.
    I found out that there is no official retrofit for CH530 and I decide to replace main switch, CTs, VTs and local cld module.
    Everything else will be repaired.
    CV
    East of big city prices.
    Quote Originally Posted by Gear-Drive Guru View Post
    Wow they never built one but boy maybe he found the very first!!!! LOL
    Jan 2012
    Perth Down Under
    As Tech Rob indicates the liquid level sensor and the exv's will be the problem.
    I have never seen this option in the CH-531 retrofit line up either.
    The only CH-531 retro that I know off is for gear drive or direct drive conversions. Have done many on the gear-drive machines and are very successful for gathering maintenance information and fault finding. Backup support is hard to come by but I have never needed this requirements
