Results 1 to 12 of 12
    Jul 2011
    Long Flexible Brush for Cleaning Condensate Trap/Line
    Hi- I have a condensate trap coming off the air handler for my AC as well as a condensate drain line coming from my high efficiency furnace. The two drains end up connecting and drain into 3/4" PVC which then drains into the sump pit in my basement.
    I'd like to find a flexible brush to run down the PVC every year to clear out any potential clogs..at least in the area of the condensate trap, if not further. Do you guys recommend anything?
    Thanks!
    Jan 2010
    North Huntingdon,Pa
    Cup of clorox prior to ac season won't hurt
    PA#9377
    Your Satisfaction...Our Goal.
    Mar 2010
    Woodbridge, VA
    I know I'm not supposed to post - but bleach going into a sump pit can get pumped out into the yard where pets might be. If a moderator removes my post - please pass this on. Thank you.
    Jan 2010
    North Huntingdon,Pa
    It's one cup,not 1 gallon
    PA#9377
    Mar 2010
    Woodbridge, VA
    Very correct one cup. And when it does pump out - it is diluted with water. So it's not a major issue but something to be aware.
    Jul 2011
    I was thinking white vinegar rather than bleach. Wha-do-ya think?
    Jan 2010
    North Huntingdon,Pa
    Great descaler!
    PA#9377
    gevans
    Additional infractions may result in loss of posting privileges.
    Your post was deleted.
    Last edited by jpsmith1cm; 02-14-2012 at 06:23 PM. Reason: Ziggyhere IS authorized to post in AOP
    Quote Originally Posted by ziggyhere View Post
    ziggyhere,
    I initially deleted your posts, taking you at your word that you weren't permitted to post here. Once I saw my error, I restored those posts.
    You ARE in fact authorized to post in AOP. Please share your knowledge.
    Virginia
    Google ezt406
    Tallahassee, FL
    Harbor freight has a nice little brush I picked up
    S.E. Pa
    Derekej, This is the Ask Our Pro's or AOP forum. In order to post responses here, you must have verified qualifications and have been approved by the AOP Committee. Please see my signature line for links to register and review the AOP Forum Rules. Thank you. Your post will now be deleted. Further infractions may result in loss of posting privileges.
