02-15-2012, 12:50 PM #1
- Aug 2011
- 9
5 Ton Rudd/Lennox/Heil AC how much RA is needed?
I have 4 contractors bidding the replacement of my 2 AC systems.
Downstrairs is 17 year old 5 ton Goodman
Upstrairs is 17 year old 3.5 ton Goodman
4400 Sqft 5 BR in Houston Texas
The existing systems both have 1 Return Air 25" x 25" grill connected to 18" flexible hose to AC system in the attic.
Only rooms upstairs are 4 bedrooms. Much of upstairs is open to the downstairs.(great room in the middle of the house)
The Rudd provider is telling me I need to add RA for the downstairs. The way the house is built it is impractical to add another RA downstairs in the traditional way. He says he is installing 4 separate 4"x8" RA on each of the 4 upstairs bedrooms. He is also proposing re-tasking the existing 25x25 fed via 18" flex hose to the downstairs 5 ton AC so that the downstairs is fed via 2 25"x25" grills each connected to separate 18" flex hoses which would be connected to the 5 ton plenum.
Does this sound right to you pros?
02-15-2012, 09:43 PM #2
According to my duct calculator, 4 4x8 registers won't move enough air for 3.5 tons. They. We'd to be 10 x 10, at least. Other than that, the design sounds good.
"Customer Service" is not a department, it's an attitude!
02-16-2012, 10:40 AM #3Both of those two Return Air grilles need to be filter grilles, using low pressure drop media type filters in each.The Ruud provider is telling me I need to add RA for the downstairs. The way the house is built it is impractical to add another RA downstairs in the traditional way.
He is also proposing re-tasking the existing 25x25 fed via 18" flex hose to the downstairs 5 ton AC so that the downstairs is fed via two 25"x25" grills each connected to separate 18" flex hoses which would be connected to the 5 ton plenum.
Then, there are no other filters used. That ought to do a fair job taking care of the RA flow needs. I compliment the Ruud provider for exposing that RA airflow requirement.AOP Forum Rules:
Rules for Posting
Rules For Equipment Owners
Equipment Owners Find a Contractor HERE!
udarrell
