Results 1 to 4 of 4
Thread: Which T-Stat allows Stage programming?
    Apr 2006
    apparently the Trane models TCONT800,801,802 etc do not allow programming of time and temperature differentials for Stage-1 and Stage-2
    which thermostats allow this?
    Rochester, MN
    I don't think anyone has that.. the stages will only come on as needed.
    Why do you ask?
    SW FL
    Programming basics
    How would Your Comfort be enhanced
    by having a Stage 2 control?
    Lower your t-stat or relative humidity settings to effectively run stage 2 in cooling mode more frequently.
    Honeywell = Trane TCONT 800's
    http://www.honeywell-thermostat.com/...l/TH8321U.html
    Page 35 in TCONT800 manual for RH setting
    http://www.trane.com/Residential/Dow...s/TCONT800.pdf
    KISS
    http://giveme5.honeywell.com/visionpro_demo.html
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
    Apr 2006
    climatouch t-stat has this feature:
    1. press touchscreen for 5 seconds
    2. select Y
    3. select Advanced Features
    4. scroll Next until..Stage1/Stage2 program options
    5. Enter value of minutes to run Stage1 before starting Stage2
    6. Enter temperature difference to start Stage2 vs. Stage1
    7. Select Menu to save settings
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
