Results 1 to 13 of 30
Thread: Gas Furnace problem -Old Lennox-
02-11-2012, 01:55 PM #1
- Feb 2012
- 9
-Hi all
I'm having a problem with my old 28yr old Lennox.
When the furnace runs it will run for about one to two minutes and then it will flame out,blower continues to run , it cools down and then it will re-fire.
So I guess the unit is running too hot?
To make a long story short a Tec came out,on the ticket he diagnosed it as a faulty gas valve,I replaced it and the problem still continues.
I call the company back out and Tec # 2 says the controller was bad so I replaced it.
The problem still continues.
Wile watching the unit go through it cycle last night I decided to pull open the filter door ,the unit continues to run as normal ,the problem goes away and it never goes off on high limit.
"The filter is new and there is nothing blocking the duct"
So I'm thinking its the blower motor or the Capacitor.But The motor spins freely and does not get hot.The capacitor looks ok but I have no Idea yet on how to test it or if even the will cause the motor to run slower or if this is the problem at all.
I'm so pissed with the company I don't want them back.
Could someone be so kind to head me In right direction,your thoughts or suggestions would be greatly appreciated.
-CW
02-11-2012, 02:10 PM #2
Professional Member*
- Feb 2008
- pulaski ny
- 1,616
when was the last time it was serviced?
02-11-2012, 02:15 PM #3
IF, and that is quite a large IF, it is indeed cycling on high limit, random parts replacement will not resolve the problem.
You need to correct the root cause which is probably related to the ductwork and not the furnace.
02-11-2012, 02:19 PM #4
02-11-2012, 02:27 PM #5
did the "company" replace the parts or did you?
http://www.youtube.com/watch?feature...&v=2kX_3y3u5Uo
http://www.youtube.com/watch?v=JVAhr4hZDJE
http://www.youtube.com/watch?v=-TC2xTCb_GU
02-11-2012, 02:43 PM #6
- Feb 2012
- 9
Snupytcb- It get serviced regularly .
Jpsmith1cm- Are you saying the returns may need cleaning?They look ok.The duct work itself hasn't changed .I will pull the returns down and have a closer look.
Gross - yes its old but its been very reliable up until now.I think a lot of Tecs today just don't know the older units.First thing they want to do of course is sell ya a new unit.
The heat exchanger is still in great shape !
Which one of the newer units have battle ship metal heat exchangers ? "Grin"
02-11-2012, 02:43 PM #7
I'm assuming this is a gas furnace and not oil? No specific equipment information doesn't give us much to lean on. Even a few pictures would at least tell us with what we're dealing. A good company should obtain the following information as they perform a thorough trouble shooting job. These won't necessarily mean anything to you but should to a good tech.
RAT, SAT, RESP, SESP, TESP, CFM. This is information that is germane to both oil and gas units. For gas furnaces, inlet gas pressure in IWC, manifold pressure in IWC, total Btu input to the furnace by clocking the gas meter. The tech may find the problem without going through all those steps but if necessary, all steps should be taken.
However, if the problem is NOT temperature related, then the possibilities are almost endless. I appreciate your frustration with the servicing company but please understand that not all techs are cracker jack aces and if the problem is beyond basic, it may take a senior tech to solve the problem. Now if THEY have been putting on the parts, I'd expect them to stand behind their work. Btu if YOU have been replacing the parts based on their opinion, then you've got no recourse for what's been done. It's difficult to determine who's on first by your description.If YOU want change, YOU have to first change.
02-11-2012, 02:52 PM #8
your unit may be border line on return
what type filter are you useing if 3m then pull it and put in a cheap one
the evape coil may also be plugged and need a good cleaning
age IMHO isnt your issue
something has changed and needs to be found if in fact it is over heating and not something else causing your problem
what ever you do
DO NOT LEAVE THE BLOWER DOOR OFF OR YOU COLUD DIE
02-11-2012, 03:02 PM #9
Actually, I'm referring to a potential airflow problem.
I cannot see the installation from here, but the symptoms that you describe MAY, and I must emphasize MAY be a low airflow problem.
I'll turn your last question about on you. How many NEW units operate at typically 50-60% fuel efficiency?
02-11-2012, 03:30 PM #10
- Feb 2012
- 9
Thank you for your response.
The company I called charges bucks for a diagnostic to find the problem.My reason for me doing it this way was to save money on labor the company would have charged to replace the part or parts needed.
I consider myself mechanically inclined enough to do the work.However I don't have the tools or knowledge to diagnose properly and didn't want to throw parts at it,even though thats what I wound up doing anyway and even payed extra
The company didn't charge me for the second Tec visit, only the first time for the diagnosis.There was nothing wrong the the work I did,it was diagnosed wrong from the start.
I wasn't home home when the first guy came out so I don know what he did .The second guy only had a multimeter and somehow determined the gas valve was bad which it was not.
In a perfect world I think I could of saved some money,my intentions were good but I think got screwed in the end .
BTW its a Lennox Gas Furnace ,the description is in the post title.I can post more info and pics if need be.
Thank you for your reply
-CW
02-11-2012, 03:31 PM #11
02-11-2012, 03:46 PM #12
- Feb 2012
- 9
The filter door is on the return side not the supply side,the flow at the registers/vents still has good flow.
I checked the fins on squirrel cage and there clean too.I have a cheap filter,fiberglass kind.
Couple pix of the unit and the unnecessarily replaced parts.If The the A coil was clogged why does the unit operate normally with the filter door open?
02-11-2012, 04:31 PM #13
- Feb 2012
- 9
