Results 1 to 13 of 18
Thread: Trane tscb
    Trane tscb
    New to site need help working on 60 ton Trane chilled water air handler. System is over cooling occupied set point at 70 the effective set point shows 40 can't figure out why. Any help greatly appreciated.
    Jul 2009
    In a mechanical room....
    Thumbs up
    Or maybe your looking at the offset and the setpoint is 40?
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Quote Originally Posted by Ctcoffelt View Post
    ...the effective set point shows 40...
    i may not be an expert, but i think that this may be your problem and not the air handler.
    ...can't figure out why...
    or it could be this reason.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Dec 2010
    New Orleans
    Quote Originally Posted by chrishvacman View Post
    And here I was thinking I was a smart arse. Boy you got me beat.. Anyways can't you relinquish the command to go back to the proper setting?
    Jul 2009
    Quote Originally Posted by keeplearnin View Post
    Ive got a hammer that's just big enough to get it back to the proper setting.
    - E.E. Cummings
    New to site not to hvac not the offset and no cant change it . Supposed to be heat sp + cool sp devided by 2
    Aug 2009
    Prattville,Alabama
    Your profile is kinda slim. No offense, but is English your first language? I ask because I wonder if that is why I don't recognize a couple of things. Is "effective setpoint" the same as "active setpoint"? And I'm not familiar with "tscb", but then I certainly don't claim to have worked on all the Trane air handlers either. Maybe it's a matter of the air handler being in "remote control" or "local control". You may think you have one, when you really have the other.
    Yes it is the same as active set point on my control module it says effective the tscb is a built air handler it has the tracer ah system I have local zone thumb will enabled
    Just a little back ground I have been doing hvac for about 10 years worked on carrier chillers here and there but not much this is the first Trane that I have worked on the company I'm doing the work for has always used Trane services so they may have set something up that I can't see been doing a little research wandering if they used the rover to set it up
    Aug 2009
    Prattville,Alabama
    Like I said, I'm not familiar with that unit. If the operator interface is similar to the Intellipak then it could be confusing to understand. Others here may be familar with what you have. Some may "bust your chops" a little bit while waiting for more info, no harm meant, I'm sure. But my first thought was, and still is, a possibility. Also it could be a matter of what sensor is selected for whichever function. Access to an IOM or a programming guide for that unit would probably be a BIG help to you.
    Just downloaded the tracer manual gonna read up a bit but thanks for your input
    Aug 2009
    Prattville,Alabama
    You're welcome, and good luck.
    does it have the 'blue screen' MP540 touch screen controller?
