02-09-2012, 09:14 PM #1
- Feb 2012
- 33
Brand new home want to change HVAC - York to Lennox ?
Hi all,
I'm about to purchase a brand new build home. Air quality is important to me. My goal was to have a zoned system, but the brain trust that built this home did not zone it. First thing I noticed when I walked to the basement was how cold it was. That being said, to install zoning will be a nightmare (tearing up basement ceiling and so forth) because there is only one supply run with ducts running from that main supply to all areas of the home. I hope to install a modulating furnace to hopefully even out the temperature throughout the home.
Here is what is currently installed:
1. York TM9X 100C20MP11A (single speed / single stage - definitely not comfortable) - 100,000 BTU
2. Air Conditioner - YCJF 36 - 3 ton unit (I believe).
The house is about 2500 square feet with high ceilings (10 foot in the basement). I believe the furnace is way oversized.
Zoning is out of the question unfortunately due to the work involved in ripping up drywall. My current home has a Lennox SLP98V with a Trane A/C unit. The comfort is amazing although humidity is a problem in the summer.
I'm thinking of ripping out the York TM9X and installing an SLP98V since it is the furnace I am most familiar with. I also would like to install an HRV. Here are my questions:
A) Is the York YP9C comparable to the Lennox SLP98V? The SLP98V doesn't modulate down, but I'm assuming the York does not as well as I don't see it having a special thermostat like the Carrier.
B) I know on the SLP98V I can interlock the HRV so when the HRV is on the SLP98V circulates air at a low setting (so it circulates fresh air throughout the home). Can the York do this as well? Will probably go with a Vanee Gold HRV with the upgraded thermostat (the HRV control will be separate - I only want it to be interlocked to the furnace fan so that it will turn on when the HRV turns on).
C) Do I need a 2 stage A/C unit to use a dehumidification setting on the thermostat in the summer? (I understand the compressor will start but the variable speed fan on the furnace will operate at a lower CFM so as to dehumidify the air). I called the installer who put the current unit into the home and he I need to replace the A/C unit with a 2-stage model because the coil will freeze during a call for dehumidification - but I don't trust him already seeing as I feel he massively oversized the current furnace.
... that's all I can think of for now. Just want to have the most comfortable home possible without zoning, and I know I can't do that with the current single stage / single speed setup.
Thanks all
02-10-2012, 03:57 AM #2
Professional Member*
- Jul 2006
- Virginia
- 3,716
The lennox furnace can be used with yhe york coil and condenser ,i would use a honeywell iaq thermostat and have it wired to slow the blower for dehumidification and run the hrv
02-10-2012, 07:02 AM #3
- Feb 2012
- 33
