Thread: slab coils & horizontal coils
02-09-2012, 07:22 PM #1
New Guest
- Feb 2012
- 1
hello all
I am relatively new to the field and was wondering what applications you would use a slab coil and a horizontal coil, I normally do very basic and simple residential a/c system installs when I do a/c work and have come across some catalogs for slab coils and I have to be honest I am not sure when or why you would use them
Not ashamed to ask I am just curious,
thanks
02-09-2012, 08:15 PM #2
Normally it's a decision made by the installer in accordance with space needs. As long a both types of coil are matched to the rest of the system, it really makes not difference mechanically. So as I stated, if the length of a box horizontal unit won't work, then a slab would be the likely substitute.
02-09-2012, 09:41 PM #3
- Jan 2010
- new orleans
- 158
Slab coils tend to be much more easier to service ( cleaning and inspection purposes). Nice for inspection of heat exchangers and static readings. We use slab coils for everything if at all possible or if it's a vertical installation .
