Results 1 to 13 of 17
    Feb 2011
    Fogelsville, Pa.
    American standard rtu induced won't shut off??
    American standard rtu md# Ycd151c4habb the inducer stays on and won't shut off. No error codes and when I run the rtu through its test modes everything comes on fine. Even when not calling for heat it still running.
    Virginia
    Quote Originally Posted by billymons View Post
    Check your e-mail for information on this issue.
    Southeastern Pa
    These units should almost have a sticky post.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Feb 2011
    Fogelsville, Pa.
    Good call gents
    Read the bulletin, is indeed the inducer. On order. Thx
    Feb 2011
    Fogelsville, Pa.
    Anyone ever just change the fasco motor and not the whole inducer assembly. The whole assembly is pretty pricy.
    Jan 2012
    inducer
    before you just replace inducer assembly you should check the burner screen behind the assembly because when they run 24-7 they tend to pack dust and dirt on the screen thus causing ignition problems
    Virginia
    I will preface this with - I have never changed an inducer motor on this particular unit.
    But on other package unit that I have replaced the inducer motor - the labor involved in trying to separate the motor from the wheel ends up being equal to or more than the price of the entire unit.
    I've never had a wheel that just pops off the motor shaft for easy replacement.
    I agree the whole assembly is pricey, but not worth the trouble trying to separate them.
    michigan
    Quote Originally Posted by rundawg View Post
    Ditto
    Jan 2010
    Boy if i could collect a dollar every everytime someone posted this.
    name a commercial tech that hasnt encountered this issue . . . . he will be a newbie to the world of service in all likelihood lol
    Jan 2012
    Central New Jersey USA
    Inducers do cause a similar problem when they short, but also make sure it does not have a separate relay (#1) on a voyager, to bring on the inducer. I recently had one stick on me.
    houston, texas
    What a pos, but go figure, Trane just keeps on using the same setup. You can get the same Fasco assembly from Johnstone minus the red gasket for considerably less money.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Feb 2012
    Alabama
    Quote Originally Posted by monkeyman#1 View Post
    Ditto
    Double ditto
