Thread: GDI30 issues
02-09-2012, 12:32 AM #1
GDI30 issues
Propane conversion
Customer said it does the following, but I have not seen it do any of this;
1) main burner will come on and go off up to 3 times rapidly, but pilot never goes out
2) booms on start up, shaking the entire unit
3) flames will be all blue for up to 5 minutes, then turn to yellow from middle up
I have checked all the install parameters and they seem correct- gas pressure, alignment, glass "ember" placement, orifices and shutter. Unit is in the basement of a 2 story house vented with flex liner up the existing chimney(first 6 feet of chimney below grade and remainder is exterior of house).
I cannot get it to do any of these while I am there. This unit has been nothing but a PITA since installed.If Guns Kill People, Do Pencils Misspell Words?
http://www.youtube.com/watch?feature...&v=2kX_3y3u5Uo
http://www.youtube.com/watch?v=JVAhr4hZDJE
http://www.youtube.com/watch?v=-TC2xTCb_GU
02-09-2012, 10:17 AM #2
Sounds like a venting issue to me. Verify the intake and exhaust are on the correct liners and the appliance collars are not packed with insulation.
Keep the fire inside the fireplace.
02-09-2012, 12:27 PM #3
Thanks!!
02-11-2012, 03:39 PM #4
- Sep 2011
- 13
Sounds like the unit might be turning on and off quickly causing gas to build up and boom. Check loose wiring or bad switch
