Results 1 to 8 of 8
    type L or type K copper pipe is used for hot water heating?
    Which type of copper pipe are you using for hot water heating system, type L or type K?
    thanks,
    Quote Originally Posted by housecarer View Post
    thanks,
    M,L,or K is approved along with others
    Massachusetts
    Any of the pipe that feeds the radiation, and after the pressure regulator can be type M, which is a thinner wall, and a little cheaper.
    Codes may be different in your area.
    Suppy NC
    m oe l copper is normal in most cases
    k is over kill IMHO
    Ontario Canada
    I would use type L copper for a boiler system. Type M is too thin in my opinion. You may not have trouble with type M, however; I enjoy the piece of mind with using type L.
    Never give up; Never surrender!
    Sep 2009
    Arnold mo
    If a new install, I'd look into pex tubing with "homeruns" to each hot water outlet from a manifold, especially in a large home. Can be a big energy saver.
    An answer without a question is meaningless.
    Information without understanding is useless.
    You can lead a horse to water............
    http://www.mohomeenergyaudits.com
    TACKERDOWN
    Your post has been deleted.
    Apr 2011
    Coastal Maine
    Quote Originally Posted by tipsrfine View Post
    While pex can be utilized for some parts of the system, it is limited by most codes with how close that it can be to the heating appliance.
    According to the UPC and UMC, type M copper can be used where the system is not exposed to normal operating conditions over 100 psig.
    In my opinion, type M can be used on residential hydronic heating systems safely. I will not use it on domestic water piping or commercial heating systems. I also will not use any copper on steam.
