Results 1 to 7 of 7
Thread: Superheat
    Target Superheat=(return wb x 3 - condensor intake drybulb -80) /2
    So let's say return wetbulb at evap. intake is 80
    and it is 80 degrees at the condensor intake
    80 x 3 = 240 - 80 - 80 = 80 divided by two = 40
    Under these circumstances you should
    have 40 degrees superheat?
    Apr 2002
    Dallas, TX
    Yes, but keep in mind that the equation you have is a simple linear correlation of some charging chart data. You don't know how accurate the correlation is at the conditions you state. And 40°F superheat will be about the TD of the evaporator so charging to this superheat may prove difficult.
    That would be right, + or - 5°
    Although at that ID WB, and OD DB, I wouldn't expect the ID delta to be much more then 10° untill the WB dropped to the mid to low 70's.
    In a rainforest that sounds close!
    Try a more normal scenario. How about 65wb and 85 out?
    In Florida we often have high humidity. But
    how can you tell what the humidity is since
    I never gave the indoor dry bulb tempt.?
    I never said you could not find some conditions
    where this equation works. I just wanted to
    know if it was always accurate. It is quite
    possible to have 80 degree indoor wet bulb
    and 85 degree or 90 degree indoor dry bulb.
    Where am I wrong?
