Results 1 to 10 of 10
    Oct 2002
    Plano, TX
    Studio duct work
    I need info on designing duct system to supply studios. Needs to isolate sound. Any hints or links.
    really depends on how critical noise is. There are many ways to do this. for example, in tv studios, we often see very large ductwork and virtually no static pressure. lots of air changes, but almost zero noise. lots of diffusers to simply allow air to drop to the conditioned space near the news desk. with a very large return on the opposing side of the room. cooling is staged on by return air temp in many cases we see, and usually on a reset schedule to prevent overcooling. due to the widely varying loads, you typically also see electric reheat for humidity control.
    Jul 2011
    East coast USA
    a few other ideas are, insulated lined supply and return ducts, if this is a plenum return Z boot returns. As duct work goes through the walls add flex collars, use duct board (least favorite) but if your concerned with the sound of "air" Flange is right on.
    But much also depends on the design of the space, walls, floor, etc..
    Arizona
    You can also buy sound deadening flex for your last 6' to 8' of connection. Talk to your supplier, as this is made for what your looking for.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Apr 2006
    mechanical room
    what about that cloth duct ? starting to see it more in supermarkets .
    Oct 2002
    Plano, TX
    Jimi- Have a product name. I'm not having any luck finding.
    Cool... Link to this product. Doesn't sound like a flag flapping in the breeze...does it?
    Jan 2005
    Detroit Michigan
    I think he was referring to Duct Socks
    http://www.ductsox.com
    Feb 2012
    San Jose, CA
    I agree with the suggestions from flange, dlove, and jimj .
    Don't forget to also consider the noise from fans and compressors. Large systems use different design approach than a small system. Not sure what you have.
    And don't forget the structure and architecture affects. And location, location, location of the noise making items.
    Jan 2010
    Be careful when using the fabric ductwork - although it is forgiving with regard to noise generated in the duct compared to sheet metal, it is terrible at keeping noise inside the duct. Any noise you have in your duct path when you hit the fabric will pass through the duct wall so you'd better knock the noise down before the metal-fabric transition.
    Boise, ID
    This topic has been discussed several times on this forum. Do a search.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
