Results 1 to 7 of 7
    Apr 2006
    I do indoor air quality assessments, which require me to inspect HVAC systems. I came across an old Williamson Oilsaver--the condensate was draining onto a concrete slab (no floor drain), causing mold to grow on the interior walls of the room. I was curious what you pros would recommend to do? Also, what type of filter do you guys feel would work best? any web page links that would be helpful? I appreciate it.
    Condensate pump the water to outside or plumbing wherever. So the water was just left to accumulate on the basement floor? Wow!
    Apr 2006
    Oilsaver
    Thanks for the advice--any recommendation on filters, or just a med-high efficiency? How often do you recommend having it serviced? I noticed the efficiency was around 72% the last time it was tested (about 1 year ago). thanks for the help.
    Oil furnace should be serviced annually but a tech who really will service it. Around here, anyway, a good oil tech is murder to find. The Oilsaver needs the flue carefully cleaned or it will plug up. The 1" pleated filters do a good job, keep them from getting too plugged.
    New Hampshire
    Gee, how much would I be worth in Indiana?
    New Hampshire
    The pay must really suck, huh?
    My coworkers do pretty well. Most of our oil is gone but still have a few diehards with it. Only 3 of 8 techs will touch it.
