Results 1 to 13 of 14
04-13-2006, 07:45 PM #1
- Mar 2004
- 5
What is the best way to leave the AC settings in a Condo in Southern Florida for the summer months when no one is living there?
I was told 65% Humidistat and 65 degrees Thermostat.
04-13-2006, 07:54 PM #2
Professional Member*
- Jun 2003
- Jacksonville, FL.
- 4,301
You wanna make sure the humidity doesn't get above 60%. And if you keep the temp. stting on your tstat at 65 don't be surprised if the electric bill is excessively high. I usually recommend keeping your tstat set at around 80 if you're not gonna be there.
WHY?
04-13-2006, 07:56 PM #3
I can't recall the exact setting on ours, but I think you are close. For some reason it seems I set ours at 60% and 75 degrees. Hope this helps.
Silence is golden - Duct Tape is Silver!
04-13-2006, 09:41 PM #4
don't have a place down there but seems to me controlling by humidity only would be the way to go. who cares what the temp is?
04-13-2006, 09:57 PM #5
Banned
- Nov 2000
- Coastal Georgia
- 34,902
Set the thermostat at 45F
Best for what? For the furniture not to complain?
04-13-2006, 10:15 PM #6IF the dehumidistat is wired to the thermostat breaking the red wire as most are those settings should prevent any possibility of mold or mildew formation.Originally posted by als361
I'm located in east central Florida and settings of 60-65% seem to provide adequate protection at minimal cost.We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
04-14-2006, 08:08 AM #7Get a good dehumidifier set at 50%RH and set the a/c at 85^F or off. This will save you $300-400 for the season. I got involved in a test on a 3 year old home. Mold problems first year with the tstat set at 80^F. Second year installed a dehumidistat on a/c with the stat set at 80^F. Had less mold but mold in closets/isolated areas. Third year install whole house dehumidifier, set tstat at 85^F, dehumidifier at 50%RH. Recorded %RH all summer. Reduced electric cost $380 for summer and maintained 50%RH- no mold. TB.Originally posted by als361
08-06-2009, 09:53 AM #8
- Aug 2009
- 4
We have purchased a mobile home in Port Richey, FL for a vacation home. What is a GOOD dehumidifier for use in the HOT Summer season when we're NOT there. Keeping the A/C on while we're not there, even set @ 80 is too expensive!
08-06-2009, 10:35 AM #9
- Aug 2006
- 2,439
The only one I'd trust would be a Sante Fe, look them up on the web.
Just a little warning, if you do not have someone checking on your place, your home owners insurance is no good. Know this to be a fact as my dad was an insurance adjuster in Florida before he died. Find out from you carrier, whats required and have a year round Senior citizen check and sign a log, that's in the home, perferably laminated and securily mounted.
Check with your Condo Association as to what's required, to keep you out of a legal bind. 65% 65 F sounds right for your set up as you do not have 'True" dehumidification. The Dehumid stat will allow the unit to come on at anything above 65%, thermostat will shut cooling off below 65 F. Not a very efficient set-up BTW.
08-06-2009, 10:51 AM #10
- Aug 2009
- 4
Thanks, I will look up Sante Fe, but ours is not a condo. It's a mobile home in a 55 and over mobile home park. We have a thermostat, but no Dehumid Stat. I'm looking for a unit that I can use mostly when we're not there. I guess it will have to drain to the outside. I do have someone who can come by & check on the place from time to time.
08-06-2009, 08:10 PM #11
- Aug 2009
- 10
I live and work in the tampa bay area. For all my seasonal customers I recommend between 55-60% humidity and 82 degree temp setting in cool.
08-06-2009, 11:21 PM #12Bear Rules: Keep our home <50% RH summer, controls mites/mold and very comfortable.
08-07-2009, 10:21 AM #13
- Aug 2009
- 4
